Dual stage set-up question??
Old Jan 18, 2003 | 04:46 PM
94DROPTOPZ28's Avatar
Right now I have a Nitrous Works universal EFI set-up on my car with the "Super Pro Solenoids" and a dual purge set-up, and I was wondering what I had to do to make this a dual stage set-up to get more traction? Could I just get 2 more solenoids and another nozzle to put in the intake and run the second stage off of a button on the steering wheel or will I have to get some kind of Nitrous controller??
I was thinking about 100 shot off of the hit and then another 50 after the car hooks up, does anybody have this kind of set-up and if so how has it worked out for ya?
Old Jan 20, 2003 | 04:12 AM
Can't anyone help me??
Old Jan 20, 2003 | 09:14 AM
markshotrod69's Avatar
I would just use a nos controller.That way you can control how much NOS to use on your lanuch to get the car to hook.The car will be more consistant with the controller than with a 2 stage NOS setup. Mark
Old Jan 26, 2003 | 12:19 AM
I heard that the progressive controllers flutter the solenoids and make them go bad after a short time can someone else please help?
Old Jan 26, 2003 | 11:29 AM
Z28ROC's Avatar
Yes, all you need are the solenoinds, nozzle, lines, Y fittings for the N20 and fuel lines, and a relay.
Then you can rig up a push-button. Or use an rpm window switch, to bring on the second stage.
Old Jan 27, 2003 | 11:56 PM
baross67's Avatar
If you go w/ a push buttom design for one of them....you could mount it on your shifter like I did. It looks trick and does the job.
good luck,
brad
DirtyDaveW
Mar 15, 2015 07:01 PM
Ws6Envy
Mar 3, 2015 04:31 PM
alphaauto
Jan 22, 2015 08:02 PM
importkiller94
Jan 17, 2015 09:03 PM
