Best posi unt?
Old Sep 28, 2003 | 07:16 PM
JuiSSed's Avatar
Best posi unt?
need a posi for my car.. Auburn? Eaton? Detroit Lockers? are they all pretty much the same?
thanks
vinnie
Old Sep 28, 2003 | 08:11 PM
silverz28's Avatar
I have an Eaton. It has held up sofar. It has carbon fiber clutches.
Old Sep 29, 2003 | 10:46 AM
JuiSSed's Avatar
i'm leaning towards the Eaton... where is the best place/price to get it?
thanks
vinnie
Old Sep 29, 2003 | 12:15 PM
TedH's Avatar
Depends on how you plan on using it. I went through a couple of Auburn Pro units with the stock rear but I was making abour 400 strip passes per year on it too. With the 12 bolt I went with the 800 pound Eaton unit. I have heard both pro and con about the smaller Eaton for the stock rear.
Old Sep 29, 2003 | 07:33 PM
JuiSSed's Avatar
i ordered my Eaton today for $330! i believe since these are clutch packs, i'll need the LSD additive? The Torsen didnt need it..
thanks
vinnie
Old Sep 29, 2003 | 08:00 PM
RamAir95TA's Avatar
You should always use the additive...
I too have an Eaton, and it just took a dump on me a few weeks ago. It's nice to know that they are fully rebuildable for under $50 also!
Old Sep 29, 2003 | 08:02 PM
JuiSSed's Avatar
how long or how much abuse before it took a dump? do you recommend the unit?
thanks
vinnie
Old Sep 29, 2003 | 08:07 PM
RamAir95TA's Avatar
Well...the poor thing has been through hell and back.
It's been bolted to 4 different gearsets, upwards of 200 passes at the strip on street tires and slicks, donuts and powerslides galore, a bad spare tire incident (donut on one axle, regular tire on the other), and it's been between the axles for 3 years. I'd say it held up pretty nicely! What I like most is that it's rebuildable. If it fails, new springs and clutches are only $48 from Drivetrain Direct, or Eaton directly. I HIGHLY recommend it, and my rebuild kit should arrive within a few days.
vwb11356
Jul 22, 2015 06:51 PM
mrwz28
Jul 8, 2015 09:11 PM
cristian1311
May 1, 2015 08:56 PM
TitoPR221
Jan 29, 2015 08:00 PM
