Best Plug for High-Compression LT Engine
Old Mar 4, 2007 | 09:15 AM
The Engineer's Avatar
I’m sure there are several posts on this subject; however, I couldn’t get the forum search function to work today.
I’m currently running the AC Delco Platinum plugs #41-943 on my high-compression 396 stroker. And, I've had some fouling problems with minimum use.
So, what is everyone’s opinion on the best spark plug to run in a high-compression LT engine and why?
WD
Old Mar 4, 2007 | 11:03 AM
rskrause's Avatar
Moderator
Well, fouling means it's either too rich or the plug is too cold. You are in the best position to judge which it is.
Rich
Old Mar 4, 2007 | 11:05 AM
96capricemgr's Avatar
Platinum does not belong in a performance engine, if you look I bet you are lossing some of the platinum pucks.
Not sure if the AFRs take the same plug as stock heads but I found NGK TR55 to not work was well with the high compression as they had when the motor was closer too stock and switched too Autolite 104s which are as easy to find as a Walmart. If you like NGK TR6 is a little cooler than the TR55.
Old Mar 4, 2007 | 11:33 AM
mdacton's Avatar
I was running the delco's then went to a 104 autolite....all the platinum tips were gone after a few weeks at the track and no street miles..also had a hi rpm miss.....I think it was blowing the spark out@.045
Old Mar 4, 2007 | 12:47 PM
96flame's Avatar
The new delco platinums don't have the problem of the platinum pucks falling off like the older ones. I was running autolite 104's and replaced them with the 104XP's which are said to have a 20% bigger flame than standard plugs. I had NGK's in and they fouled within a few days not a fan of NGK plugs. My compression ratio is a bit over 11:1 btw.
Old Mar 4, 2007 | 01:51 PM
sbs's Avatar
sbs
Please point us to a reference on this design change. When did it happen?
Old Mar 4, 2007 | 02:43 PM
96flame's Avatar
Sorry its the new iridium ones that I am refering to. Thats what comes original in the GM's now and I have yet to see one with the puck missing on the ground electrode.
http://www.acdelco.com/parts/sparkplugs/iridium.jsp
Old Mar 4, 2007 | 11:25 PM
Try the Autolite 103.
Old Mar 4, 2007 | 11:30 PM
blackztpi's Avatar
i don't see how you can be running cold on a platinum plug. i always use tr6's on my 11:1 setup. they work fine. bret bauer suggested i use these or a similar plug to be safe. I've yet to foul one out after 4k miles
Old Mar 5, 2007 | 09:25 AM
jimbob65's Avatar
WD
I use the Autolite 3910 (heat range 9, I believe) on the AFR heads...Works great. Takes just a little longer, maybe 10 seconds (at most) in the morning before cleaning up (over my old heat range 4 plugs).....These are the same plugs I used when I had a 248/248 on a 109 LSA Duration cam in there, with 8 1/2 inches of Idle vacuum. It's all in the tune...I have atleast 50 flashes (including cyl balancing) just for idle area...
Old Mar 5, 2007 | 11:42 AM
foggedz's Avatar
Ngk Br7ef
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
centric
Aug 15, 2002 09:04 PM
