Best Plug for High-Compression LT Engine
I’m sure there are several posts on this subject; however, I couldn’t get the forum search function to work today.
I’m currently running the AC Delco Platinum plugs #41-943 on my high-compression 396 stroker. And, I've had some fouling problems with minimum use.
So, what is everyone’s opinion on the best spark plug to run in a high-compression LT engine and why?
WD
WD
Platinum does not belong in a performance engine, if you look I bet you are lossing some of the platinum pucks.
Not sure if the AFRs take the same plug as stock heads but I found NGK TR55 to not work was well with the high compression as they had when the motor was closer too stock and switched too Autolite 104s which are as easy to find as a Walmart. If you like NGK TR6 is a little cooler than the TR55.
I was running the delco's then went to a 104 autolite....all the platinum tips were gone after a few weeks at the track and no street miles..also had a hi rpm miss.....I think it was blowing the spark out@.045
The new delco platinums don't have the problem of the platinum pucks falling off like the older ones. I was running autolite 104's and replaced them with the 104XP's which are said to have a 20% bigger flame than standard plugs. I had NGK's in and they fouled within a few days not a fan of NGK plugs. My compression ratio is a bit over 11:1 btw.
http://www.acdelco.com/parts/sparkplugs/iridium.jsp
i don't see how you can be running cold on a platinum plug. i always use tr6's on my 11:1 setup. they work fine. bret bauer suggested i use these or a similar plug to be safe. I've yet to foul one out after 4k miles
WD
WD
Alex Barnes
Jan 24, 2015 10:21 PM
centric
Aug 15, 2002 09:04 PM
