Best EWP
Old Jan 13, 2009 | 11:23 PM
mrl510's Avatar
Best EWP
What is a really good electric water pump for street mostly and a little strip. Brand wise what would be one of the best to go with. Also how long can i really get out of the water pump? Thanks
Old Jan 14, 2009 | 12:07 AM
henryz28's Avatar
I have the CSR and put over 10,000m on it. Car runs at about 170 with the 160 thermostat; never over heats.
Old Jan 16, 2009 | 06:42 PM
mrl510's Avatar
thanks
Old Jan 17, 2009 | 10:16 AM
Might help if you mentioned what engine you plan to put it on.
Old Jan 17, 2009 | 02:33 PM
speedracer2j's Avatar
My vote is for the Mezeire. I ordered from Summit. Required only a little trimming of the shroud, bolted right into the housing without trimming the housing. I think the HD version requires alot more trimming of the shroud. But my 11:1 383 only runs 170-180 in 90+ degree temps...
Old Jan 17, 2009 | 04:36 PM
sn8ke eatr's Avatar
meziere gets my vote, but im bias because i have one
Old Jan 17, 2009 | 05:57 PM
1989TransAm's Avatar
I also have the Meziere water pump. Has worked just fine for me. This is the only electric water pump I have had so I can't compare to others.
Old Jan 18, 2009 | 02:35 AM
94307's Avatar
I have a Meziere HD and it fits fine. I had to trim the shroud, but did not have to trim the blades any. I have had it for about five+ years and 30+k miles with no problems.
Old Jan 18, 2009 | 11:12 PM
mrl510's Avatar
The EWP would be going on my blown 383 lt1. I just want a good pump that is good for street use and keeps an engine cool in 90+ degrees. Thanks for the input so far. Looking like im turning towards the meziere instead of csr
Old Jan 19, 2009 | 12:01 PM
camaro383tt's Avatar
Member
shouldnt you be movign this out of advanced tech?
Old Jan 19, 2009 | 05:06 PM
I asked him for the engine type, so I would know where to move it. Now that he's told me what engine it is, I can move it. Please be aware... not all off us have time during the day to respond to each and every post. Please let a day go by before you decide to "Report this post" for something like "wrong forum".
Old Jan 19, 2009 | 06:10 PM
96capricemgr's Avatar
With a blower keep the mechanical pump, contrary to popular stupidity it moves more water at moderate and high rpms, at low rpms when the electric would move more water there is no load and cooling requirements are minimal.
Old Jan 22, 2009 | 03:36 PM
LSWHO's Avatar
Is there an EWP that doesn't require modification on an LT1??
Jlo
Feb 3, 2015 09:41 PM
dutss707
May 21, 2006 07:45 AM
350 HRSS
May 18, 2006 07:45 AM
fast96lt4
Feb 20, 2006 08:34 PM
HardcoreRM125
Dec 30, 2005 10:59 AM
