Best Clutch for mid-high 11s
Old Apr 29, 2003 | 01:05 AM
unTAmedLS1's Avatar
Im just looking for something with a little streetability at least and that will nice launches for a while. Im not one to ride the clutch a lot either so a nice grab would be just dandy. Not that Im running 11s or anything
Old Apr 29, 2003 | 10:12 AM
BBB's Avatar
BBB
I really like my McLeod Street twin. From racenet.net it cost me $904 shipped (comes with a flywheel and new master cylinder).
They say it is good to 1200 ft/lbs of torque. It also is not as tempermental as a carbon fiber, kevlar, ceramic, or other "puck" design clutches.
BBB
Old Apr 29, 2003 | 10:38 AM
Dave 96TA's Avatar
Everyone seems to like the newly redesigned SPEC Stage 3. You can choose from Kevlar, Carbon, or Ceramic (in that order, street to race-only). I went with the Stage 3 Carbon and SLP LT4 pressure plate. The PP is around $250 and the disc itself is around $170. You can get a complete PP & disc set from SPEC - I installed the LT4 one not too long ago and they said its the same as the one they use.
Old Apr 29, 2003 | 11:40 AM
texanmutt's Avatar
He did say he wanted a streetable clutch. Spec is not the way to go. Spec has "redesigned" their clutches time and time again and they all suck.
Old Apr 29, 2003 | 01:14 PM
Dave 96TA's Avatar
great thanks for the wise words and a solid recommendation...
..oh wait
Old Apr 29, 2003 | 03:08 PM
unTAmedLS1's Avatar
Yeah I was thinking about the McLeod the only thing is price. It kinda hurts to spend almost a grand on a clutch. Thats half od a 12bolt or a 9" which will be needed soon
Old Apr 29, 2003 | 03:23 PM
96speed's Avatar
Spend now or spend later. I would go with the street twin again in a heart beat.
You can rest assured it is going to work.
Ryan
Old Apr 29, 2003 | 09:10 PM
BBB's Avatar
BBB
The thing about a street twin is that they come with everything (at least it did when I ordered it from racenet). Price out the components seperately and it isn't as expensive as it first might seem. Most Kits are just a disk and a pressure plate. The Street twin is the throw out bearing, the pressure plate, 2 disks, a floater, a flywheel, and a master cyl. All of it is set up from the factory for instant install. Hell, if I can do it anyone can. It dosn't chatter like a puck style disk will (ceramic and carbon fiber) and it wil NOT slip.
I made my decision to get the street twin when I did a search here and found that it was the only one that nobody was complaining about.
BBB
Old Apr 29, 2003 | 09:31 PM
unTAmedLS1's Avatar
yeah Ive been thinking and most likely will go with it
Old Apr 30, 2003 | 03:26 PM
IllusionalTA's Avatar
Go w/ the Mcleod and you won't be dissappointed.. When it gives out in 2 years.. you can have it rebuilt for about 375 or so w/ the cost of inflation and stuff over the next 2 years.. i just paid 325 shipped to my door to have mine completely rebuilt after my clutch fork bolt commited hari kari on the pressure plate.. over 2 dozen 5K dumps and thousands of hwy driven miles and it still had plenty of life left in it.. Only downside is you need to def. beef up your drivetrain as your guaranteed to break a 10 bolt and everything else behind it if your not careful.. Good Luck.. As for the spec clutch.. IMHO i think they are junk.. I know they have redesigned them and what not.. I'm the reason for the redesign.. I have nuked every 2 kevlar Stage III's.. They stopped making kevlar and Stage III in the same sentance.. Then they sent me a ceramic.. Well not only was it On/Off clutch.. it never seen the track and it blew out a spring.. So i got tired and requested a 6 puck unsprung hub'd disk w/ a pressure plate.. They willfully' sent me one.. ANd then i unloaded it on here still in the shrink wrapping for lot less than a GP could ever get it.. he's happy and i'm happier.. And now look.. thats what they are selling to you guys now.."the Redesigned" one.. but i have heard of other people having problems w/ them as well.. No company is going to be perfect in their product and their ability to be able to stand behind their stuff and back it regardless of what you do to it.. Sets Mcleod apart from the rest of them.. The personable service is top notch and you get the fact's.. Not the run around as i have had in the past dealing w/ spec..
Old Apr 30, 2003 | 03:35 PM
texanmutt's Avatar
..oh wait
Well if you knew how to drive your car or anything about F-bodies you might actually know a thing or 2 about the history of spec clutches with your 103mph long tube headered car doing 2.194 sixties on nitto's.
Old Apr 30, 2003 | 04:01 PM
MYT30TH's Avatar
I've nuked two clutches to date Stock & LT4/LT1 (SLP set-up) both were fine with street tires , but add Nittto's and they wont last long at all ... especially in an M6 when you heat them up and go for something below a 2.0/ 60'. (In six passes the LT4PP/LT 1 disc.) was failing Do what I did and get the SteetTwin and never worry about your clucth again .
Old Apr 30, 2003 | 07:29 PM
texanmutt's Avatar
The slp clutches are not very good either. I've burnt up an slp disc in 4 passes on street tires. Mcloed would be the best way to go. They have great customer service. After a year and a half of abuse my clutch poped a spiring out of the hub when I did a mean downshift. When I called them they just had me send it in and they shipped me a brand new disc, no questions asked. They didnt even ask me when and were I bought it.
Old Apr 30, 2003 | 09:22 PM
rskrause's Avatar
Moderator
The Street Twin is the only aftermarket clutch worth getting.
Rich Krause
Old Apr 30, 2003 | 09:40 PM
got_hp?'s Avatar
id like to know why the f'ck our clutches are so expensive.................theyre for a transmission in a HUGE amount of cars, and almost everyone buys one...........why are they so much.
i can understand $400-500...........but $900 just doesnt seem right.
