Best cam for mid 12s on stock heads?
Old Jan 20, 2004 | 02:38 PM
  #61
96LT1TX's Avatar
I would also be interested in this subject... NightTrain any ideas on port matching to the xe230/236? I finally installed it
Old Jan 20, 2004 | 03:36 PM
  #62
MauriSSio's Avatar
there NO REAL way to port match heads for a cam.If the cam is large the only real thing you can do is enlarge the ports, since bigger cams breathe better up top (duration). Obviously you can do other stuff when you port (blending the bowls and such). Also the Hot Cam works well with the stock heads because the stock heads pretty much flow good enough for about 400HP and that cam will make about that much HP on stock heads,you can go bigger and lose some driveability/rougher idle and youll gain some HP but the gains will be pretty minimal cuz stock heads really cant support too much more HP NA (dont flow enough air). Allso the LT1 heads have basically the same size ports (170cc) and valves (1.94I/1.5E) as most other standard issue SBC heads.The difference is the angle at which the intake ports are design at.But stock LT1 heads (aluminum) dont flow much better than regulr SBC heads (about 20X CFM).
Old Jan 20, 2004 | 04:01 PM
  #63
LS1_03's Avatar
I'm sure stock injectors would be fine to run on a Hotcam setup as well? If not, I'm definitely sure 30# would be fine. But I also can't help but think the stockers are enough. Anyone care to clarify this?
Old Jan 20, 2004 | 04:06 PM
  #64
FacelessZ's Avatar
There is such thing as port matching heads for ligher mid-lift numbers as opposed to just achieving high upper-lift numbers at .600". For the 230/236, I'd imagine its more mid to upper lift numbers, not just increased upper lift numbers...
Yes it can be done...not an EXACT match but better than just "portin' the hell" out of a pair of LT1 heads...
Old Jan 20, 2004 | 04:37 PM
  #65
Z97LT1's Avatar
Hmmmm....not much variation on what people think in this thread.
A buddy of mine (z28ke on here) just finished a cam install on his stock headed '93 Z last week. Car is an M6 with CAI, Hooker LT's, cutout, and airfoil.
We took it to get dyno tuned at Carolina Auto Masters in Durham. With the cutout closed running through a Flowmaster AT catback, the car made 342 rwhp and something like 334 rwtq.
Opened the cutout, and it did: 354.6 rwhp and 343 rwtq.
Still stock heads and ~60k mile stock shortblock, and here's the kicker: we had 3 degrees of timing pulled because he also runs a 150 shot. Also, the car was burning oil and smoking bad on the dyno because of a bad valve seal.
The cam was a custom grind spec'd by Jeff at www.carolinaautomasters.com
With Jeff's tuning, it drives pretty much like its still stock.
Old Jan 20, 2004 | 04:47 PM
  #66
FacelessZ's Avatar
+12 rwhp by opening the cutout?! You sure...?
Old Jan 20, 2004 | 05:22 PM
  #67
MauriSSio's Avatar
any idiot who knows anything about or knows how to port heads KNOWS that increasing flow throughout the WHOLE lift range is important,reguardless of which cam is going in.OBVIOUSLY increasing flow @ .600 is pointless. The XE230 aint the only cam with below .600" lift.THATS what i was getting at.
Old Jan 20, 2004 | 05:25 PM
  #68
FacelessZ's Avatar
I understood what you were getting at with your last post. Of course increasing flow throughout the entire board is the point, obviously...but maximizing at certain points is whats known as "matching" a certain cam and I believe it can be done with this one...
You wouldn't need as much gains in certain RPM ranges if your cam isn't putting out at that range, so maximize where it IS putting out...
That's MY point...
Old Jan 20, 2004 | 05:28 PM
  #69
MauriSSio's Avatar
you're talkin about RPM ranges when you should be talkin about LIFT ranges, The RPM range is gonna be MORE dictated on the size of the ports themselves
Old Jan 20, 2004 | 05:34 PM
  #70
MauriSSio's Avatar
Also,cams are hitting their max lifts at every RPM and every RPM point which is why youd want flow numbers to be increased throughout the whole cam lift range,so that you get power accross the board.Since LT1 heads have small (170cc) runners,then they are pretty much gonna be the restriction point (in terms of increasing power @ high RPMs) the best way to increase the RPM's is to enlarge the ports themselves. IMO 170cc heads ported that flow 250cfm will get you a much stouter powerband than 200cc heads that flow 265cfm. <-----just an example
Old Jan 20, 2004 | 05:42 PM
  #71
Dan K's Avatar
Stockers are fine.
Old Jan 20, 2004 | 05:45 PM
  #72
MauriSSio's Avatar
stock 24# SHOULD be fine,but ive seen them take a dump with less
Old Jan 20, 2004 | 05:46 PM
  #73
MauriSSio's Avatar
what HP levels is the stock Fuel Pump good for???
Old Jan 20, 2004 | 08:19 PM
  #74
Z97LT1's Avatar
Yes.
Old Jan 22, 2004 | 12:48 AM
  #75
96LT1TX's Avatar
you run a 13.8@102... please tell us your tuning secrets...
