Best cam for mid 12s on stock heads?
Old Jan 19, 2004 | 12:41 PM
  #16
LS1_03's Avatar
Originally posted by MauriSSio
do any of you guys ever smog your cars?
Smog? What's that? We have no smog where I live, so I plan to finish the deletion of the smog crap when I do a cam. I'm already doing the !cat mod, next up is !air and !egr.
Old Jan 19, 2004 | 12:55 PM
  #17
toegead93's Avatar
I plan on keeping my stock heads and I'm instaliing the Crane 210/224 this summer. It's a small cam, but it has a broad, flat torque curve. It fit's the LT-1 very well. Look around, a lot of people are running mid/low 12's with it, some are even running high 11's. The hotcam is another great choice for stock heads and it comes in a kit, so it's real cheap. I should be running mid-12's with my setup and the 210/224. Then it's just a matter of traction, suspension, weight, and driving to go faster. Smaller cams yield great results, it's not always better to have the biggest cam you can find. You'll have issues with streetablity, emmissions, tunning (should tune any cam, but you may run into more issues with a larger cam). just food for thought.
Old Jan 19, 2004 | 01:02 PM
  #18
LS1_03's Avatar
That is all very true. I've thought about the Hotcam kit many times. I want mid 12's for now, because that's pretty attainable. I'm open to any and all suggestions. I'm also kind of partial to some serious lope. Although, I guess with something smaller like a hotcam, you could lower the idle.
Old Jan 19, 2004 | 01:12 PM
  #19
MauriSSio's Avatar
why have a seriously mean sounding lope, when you aint gonna be makin some serious HP? just go with the torquier smaller cam,what you give up in HP you make in TQ, AND its more driveable and more of a sleeper. With 3.42's i wouldnt suggest gettin a cam that will rev much more than 6000 or so.Also a much higher stall TC will be needed for a bigger cam,which will generate more heat and kill the tranny quicker. For some reason (dont know why) im not a huge fan of the HOT Cam. In my stroker LT1 Caprice i had the Comp 503 with 224/230 duration and she ran like a BEAST.
Old Jan 19, 2004 | 01:23 PM
  #20
toegead93's Avatar
the hotcam comes with a 114 lsa or a 112 lsa (which will lope). the 210/224 is 112, but from what I've heard it doesn't lope much b/c it's small.
Old Jan 19, 2004 | 01:25 PM
  #21
MauriSSio's Avatar
ok,but i meant why would you WANT a lopy *** cam,when its only gonna be makin not too much HP? And the Hot cam has 112LSA
Old Jan 19, 2004 | 01:31 PM
  #22
LS1_03's Avatar
I'm aware of the Hot Cam having a 112 LSA. I'm simply looking for several opinions on cams that are known to give me what I'm looking for. Also, who doesn't love lope? I'm leaning towards the Hot Cam for right now, just because it comes in a kit that is under $700. It's very appealing.
Old Jan 19, 2004 | 01:33 PM
  #23
FacelessZ's Avatar
Try for under $600...
Old Jan 19, 2004 | 01:35 PM
  #24
MauriSSio's Avatar
we all like lope,but to have a lopy *** car thats only putting out about maybe 400HP out of a 5.7 is kinda rediculous.
Old Jan 19, 2004 | 01:36 PM
  #25
MauriSSio's Avatar
ive heard to hot cam before,some people say it lopes hard,sounded stockish to me.
Old Jan 19, 2004 | 01:44 PM
  #26
LWillmann's Avatar
LS1_03: You will be happy with the 3.42 gears when you get them installed. My 96 A4 w/ 2.73 went a best of 14.299 @ 97-98 before the gear install. Now with my 3.42s (before headers) I ran 14.01 hitting the rev limiter in 2nd before going to 3rd due to programming issue.
Now I have headers, and am working on some tuning to fix my shifting problem, and get the fueling right.
After that, it's time to consider a cam.
I am thinking I'll either run a HotCam or a 224/230 because I want a mild cam that won't kill my valvetrain. I don't want high lift, and I don't want to have to port the heads for a while.
Good luck!
Old Jan 19, 2004 | 02:20 PM
  #27
LS1_03's Avatar
From where? PM if you want to tell me and keep it secret. I've checked a few places and the cheapest I've seen it is $659.
I know I'll be happy with the 3.42s I've ran what I ran in my sig, I think it's got more in it with a different launch technique. We'll see. I'll probably get LTs before the cam. Depends on what I get when taxes come back.
Old Jan 19, 2004 | 02:24 PM
  #28
Jay-Roll's Avatar
I've also heard great things about the GM847.
Old Jan 19, 2004 | 02:29 PM
  #29
GREGG 97Z's Avatar
Last year around this time I had just broken into the 12's (12.97) with boltons. Then I added the hotcam kit and was hoping to run at least mid 12's with it. It's certainly not the biggest or best cam out there but I'm happy with what I've gotten out of it so far.
Old Jan 19, 2004 | 02:38 PM
  #30
LS1_03's Avatar
Impressive.
