best cam 383 for daily driver
Old Jun 19, 2003 | 06:19 AM
stlws6's Avatar
i need to get my cam soon i want to get a cam for my 383 that can produce the most power and not shake the car to death i am putting in a 3400 stall and a 200 shot in the future i want a cam that is relieable some thing that wont kill the heads and springs and no emissons
Old Jun 19, 2003 | 09:28 AM
You're going to find that all the people with LT1 strokers post on "LT1 Tech"........ so you will get more/faster responses on that forum.
Moving to LT1 Tech.....
Old Jun 19, 2003 | 10:04 AM
Chris'SS #2152's Avatar
Custom ground comp cam just keep the lobe down and it will not shake the car as bad but also might hurt power some.
Old Jun 19, 2003 | 10:11 AM
Gripenfelter's Avatar
I have an XE 230/236 with a 112 LSA in my 383. Very streetable but you might want to look at something with a bit more LSA if you do a 200 shot.
Old Jun 19, 2003 | 12:03 PM
Serial Thriller's Avatar
Lots of folks are pleased with the CC306 in that application. Also check out the Comp Extreme Energy grinds (as Grip mentioned).
Old Jun 19, 2003 | 12:33 PM
thewinner's Avatar
sent you a PM
Old Jun 19, 2003 | 12:50 PM
zhevy-1's Avatar
GM 214-224 is a nice cam. I think it's also known as 845??!!
Old Jun 19, 2003 | 02:02 PM
Kain's Avatar
If you want a little lope, LT4 hot cam will be nice. Or if you want less lope, CC305 would be cool too. If not, maybe an XE 224ish cam.
I daily drive on my CC306 (still stock displacement though), and I get horrible gas milage, and it doesn't like crusing under 2000 rpm.
Old Jun 19, 2003 | 02:25 PM
magius231's Avatar
a 383 due to the larger displacement will actually lope less with a big cam then a 350 will, so you can go a bit larger without sacrificing driveability. I would look into one of the smaller comp grinds, especially something like the 218/224 which people seem to like. If you can get it on a 114 lobe, it will have even less lope and probably be better for an N2O shot.
You will likely be giving up some power compared to a bit larger cam though.
Old Jun 19, 2003 | 06:06 PM
MPM IV's Avatar
I just had my motor rebuilt and went with a comp. custom with 228/236 .533in .555ex on114* the car made 400rwhp with mac headers, a cat and a borla cat back with the solid plate sending everything through the muffler. Sounds good, but definately less lope than my cc306. Hope that helps.
Old Jun 20, 2003 | 07:53 AM
HungryT/A's Avatar
I'd get something around the XE 230/236, but the 224/230 would be prolly *** smooth as stock in the 383. I'd stay away from the LT4 HOT cam...
Old Jun 21, 2003 | 08:33 AM
brand-x's Avatar
cc305
Old Jun 21, 2003 | 10:49 AM
REPO's Avatar
Xtreme 236/242 here. No problems driving it anywhere.
Old Jun 21, 2003 | 12:22 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
if you do a search- most top guys are saying
short durration, high lift, strong valvetrain, light valvetrain, good heads.
200 shots and reliablity probobly aren't best friends either...
i suggest a nitrous grind if you plan on spraying
alex5366
Feb 17, 2015 08:12 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
deadmanrunning
Jan 3, 2015 01:12 PM
cmdeshon
Dec 12, 2014 10:51 PM
Snoman73
Nov 17, 2014 07:22 PM
