best cam 383 for daily driver
i need to get my cam soon i want to get a cam for my 383 that can produce the most power and not shake the car to death i am putting in a 3400 stall and a 200 shot in the future i want a cam that is relieable some thing that wont kill the heads and springs and no emissons
If you want a little lope, LT4 hot cam will be nice. Or if you want less lope, CC305 would be cool too. If not, maybe an XE 224ish cam.
I daily drive on my CC306 (still stock displacement though), and I get horrible gas milage, and it doesn't like crusing under 2000 rpm.
a 383 due to the larger displacement will actually lope less with a big cam then a 350 will, so you can go a bit larger without sacrificing driveability. I would look into one of the smaller comp grinds, especially something like the 218/224 which people seem to like. If you can get it on a 114 lobe, it will have even less lope and probably be better for an N2O shot.
You will likely be giving up some power compared to a bit larger cam though.
I just had my motor rebuilt and went with a comp. custom with 228/236 .533in .555ex on114* the car made 400rwhp with mac headers, a cat and a borla cat back with the solid plate sending everything through the muffler. Sounds good, but definately less lope than my cc306. Hope that helps.
if you do a search- most top guys are saying
short durration, high lift, strong valvetrain, light valvetrain, good heads.
200 shots and reliablity probobly aren't best friends either...
i suggest a nitrous grind if you plan on spraying
