best cai
Old May 29, 2005 | 07:48 AM
  #31
Jeff95TA's Avatar
Re: best cai
Originally Posted by ak_WRX_Z28
thanks for the picture. would that intake work with a Trick Flow intake elbow?
also, how's the sound?
There is definitely more intake noise, but it's not bad. This is also with an AS&M 54mm TB & 1LE elbow.
Old May 29, 2005 | 07:50 AM
  #32
Jeff95TA's Avatar
Re: best cai
Originally Posted by buzz12586
Where can I find the AS&M CAI?? Also what different elbow would I need?
I got mine from Thunder Racing. You can use a stock elbow, 1LE, not sure about the Trick Flow but I would think that would work too.
Old May 29, 2005 | 08:02 AM
  #33
Feenix's Avatar
Re: best cai
I like moroso, had bad experience with K&N from another buddy with the filter constantly falling off, but nothing but love for my Moroso
Old Jun 2, 2005 | 08:03 PM
  #34
ak_WRX_Z28's Avatar
Re: best cai
hey everyone, i just got the K&N kit. has anyone had problems with water getting on the filter? i have a pre-charger (filter cover) that i was thinking of putting over the filter. i've also read of people having their filters fall off. is there anything i can do to prevent that? also, any tips anyone can give before i start installing?
thanks
Old Jun 2, 2005 | 08:12 PM
  #35
My94T/A's Avatar
Re: best cai
You got the K&N system which is similar to LPE and Moroso. Then i am guession the air duct put's the filter in the fender. If it's in the fender it's covered on the side and underneath by fender shield and bottom shield. And as off the filter coming loose just tight the strap on the filter after you connect it to the duct. Just tight it as much as you can and just check every now and then.
Kinglouui
May 26, 2016 11:05 AM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
surreybrad
Aug 10, 2015 09:34 AM
