bellhousing help
Old Feb 3, 2004 | 09:00 PM
jeepz28's Avatar
bellhousing help
all right I just got my transmition out and started to take the bellhousing off but it wont move. I took all 6 bolts out, and tryed to prey it with a crow bar and it still wont move. Could it be just stuck or is there a bolt That I dont see. I just dont want to break the bellhousing.
James
Old Feb 3, 2004 | 09:01 PM
Red96Lt1's Avatar
A4 or M6?
Old Feb 3, 2004 | 09:02 PM
jeepz28's Avatar
m6
Old Feb 3, 2004 | 09:04 PM
Red96Lt1's Avatar
Have you pulled the clutch fork out?
Old Feb 3, 2004 | 09:09 PM
jeepz28's Avatar
yes the whole transmition is on the ground and the dust cover is off the back
Old Feb 3, 2004 | 09:12 PM
Red96Lt1's Avatar
My bad, I misread your post, I thought it was still in the car. When I did my clutch I never pulled the bell housing, but I would assume that you could pry on it. There's no sealing surfaces right?
Old Feb 3, 2004 | 09:13 PM
jeepz28's Avatar
not that I can see I hove no clue
Old Feb 3, 2004 | 09:17 PM
Red96Lt1's Avatar
From what I remember, nothing seals to it, it's just there to basically encompas the clutch and to hold the tranny to the engine. I would check for a gasket hanging out, if there are none (which I don't think there are) pry away.
Old Feb 3, 2004 | 09:19 PM
jeepz28's Avatar
thinks a lot for all your help
Old Feb 3, 2004 | 11:51 PM
Re: bellhousing help
Originally posted by jeepz28
...... I took all 6 bolts out, and tryed to prey it with a crow bar and it still wont move. Could it be just stuck or is there a bolt That I dont see.....
From my memory, and looking at a picture I took of the bell housing, there are 8 bolts that hold it to the engine. Might explain why you are having a problem.
wytblur
Jun 3, 2003 02:36 AM
IrocSS85
Jun 2, 2003 10:20 PM
turboSpeed
May 13, 2003 06:21 AM
00LukeyWS6
Apr 15, 2003 08:55 PM
