Battery relocation problem. HELP!
Old Feb 4, 2011 | 03:21 PM
The SRZ's Avatar
Exclamation Battery relocation problem. HELP!
Trying to figure out what I did wrong. I've got a the Taylor relocation kit (Summit) and Innovative Battery Cables. Followed the instructions but I'm still dumb founded on what I've done wrong.
Used the innovative cables by having 1 gauge cable to the starter in junction to the alternator, and then to the NEW junction block using this kit here remote battery terminal block & 200A fuse block
I then bought 0 gauge for the battery in the trunk and ran it to the starter. The negative post is connected to the frame.
Here's the problem, as soon as I connect the + cable to the battery the car goes hot w/ out any key in the ignition! XFI turns on, fuel pump primes, security light goes off, check gauge goes off and the brake lights are on. I looked everything over to see if anything was pinched etc but I'm getting ready to go back to stock and see what it does.
Any ideas?! Thanks!
Old Feb 4, 2011 | 03:40 PM
Guest47904's Avatar
Guest
Make this more clear please.
Are you saying there is a wire to the starter from the battery. AND another wire from alternator to the battery?
Please lay out the wiring.
Old Feb 4, 2011 | 04:26 PM
The SRZ's Avatar
Re: Make this more clear please.
Sorta, battery to starter 0 gauge, 1 gauge from starter to alternator to junction.
Never ask a chef to wire your car! LOL Somewhat figured it out but it has something to do w/ my newly wired up Linelock. Don't ask as I'm still trying to figure that one one but I disconnected the wiring for it and now all is normal in the world again. Got to go over my wiring for the LL. Always something but thanks guys. I'll definitly post the outcome w/ the LL.
Old Feb 4, 2011 | 05:33 PM
Re: Battery relocation problem. HELP!
See if this helps:
http://para.noid.org/~lj/Battery/TrunkBatt.htm
Old Feb 4, 2011 | 06:53 PM
The SRZ's Avatar
Thanks Fred. I got it sorted out.
Devinfoote87
Feb 12, 2016 03:21 PM
weedog
Aug 15, 2015 08:23 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
