battery - insufficient power
Old Nov 26, 2003 | 03:26 AM
pvkn1ght's Avatar
I've got a Sears Die Hard battery in my car (it was in there when I purchased it in Sept), but it's not the "Gold" but a lower model. Now a buddy of mine mentioned to me that only the Gold Die Hard battery matches factory AC Delco specs ?
Could this be a contributing factor as to why my engine takes a long time to crank? Could this rob HP?
Thanks | Brian
Old Nov 26, 2003 | 04:58 AM
Spinner's Avatar
Long crank, you should look elsewhere.
Old Nov 26, 2003 | 04:59 AM
S.J.S.'s Avatar
Uh........No. Not if its a brand new battery only 3 months old. What do you mean "long time to crank"? As in you turn the ignition and nothing happens then it starts to turn over, or it turns over and over before firing up?
Old Nov 26, 2003 | 05:05 AM
Van5150's Avatar
S.J.S tell him how long you cranked over your 383 before it started up, tell him....
** This message was brought to you by the supporters of The S.J.S-383 BAN Bill **
Old Nov 26, 2003 | 05:19 AM
S.J.S.'s Avatar
Van you retard........let me think........about a millisecond.
Old Nov 26, 2003 | 10:31 AM
pvkn1ght's Avatar
millisecond my 91 TransAm 305TPI fired up very quick also, ~2cranks.
i purchased my current 95 with the battery already in it (not a new battery). the starter seems rapid/consistent enough, just takes a long time to start (approx 4-5 full seconds average, 16-20 cranks?) i was just wondering if a less powerful battery would have trouble starting the 5.7L, kind of like when you try to get a jump start off of a 4cyl or 6cyl car and it's hard to do ?
related issue: the car also revs up to 1900-2000rpm for about 10-12secs when it has been recently turned off and is restarted in a 5-15minute period. if i restart the car any sooner or any later, it fires up normally
anyone?! btw, TB & IAC has been unbolted and cleaned, no difference...
thanks for the help | Brian
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
97z28k&N
Jan 9, 2015 04:58 AM
XtremeLt1
Sep 13, 2002 08:50 PM
