I got 1.7's!!!!
Old Nov 26, 2003 | 09:33 AM
Mustang4Lunch2's Avatar
I got 1.7's!!!!
well i just put on scorpion 1.7 ratio roller rockers. i did have the lt4 hot cam kit 1.6's.
all the parts i did along w/ the roller rockers. were crane double coil springs, comp cams guide plates, comp cams chromeoly push rods, and arp 7/16 rocker arm studs. along w/ new valve seals. i will just say this. OH DAMN!! it pulls sossoooo much harder up top than before. i used to be able to tell by the cams power band when to shift and yesterday when i took it out for the first time i was like ohhhh my god, crap i have to shift now. it just didn't stop pulling. OH JUST AN FYI my stock valve covers did not fit. they had to be modified in order to work. well just thought i would throw my input in on this. since lots of talk has been said lately about doing 1.7's.
Old Nov 26, 2003 | 10:07 AM
LWillmann's Avatar
It's not obvious by your post, but are you running the stock cam or the LT4 Hotcam?
Did you have to make any tuning changes for the new rockers?
Can you please explain what changes you have to make to the valve covers to work with the rockers?
Old Nov 26, 2003 | 10:18 AM
yes i have the lt4 hot cam. no tunning was required for the new roller rockers. just put them on so to speak and off i went. as far as the valve cover modification. the little bridge things thats by were the valve cover bolts go is what i had to cut out. so hope this helps you out some.
drewstealth's Avatar
It says he has the hotcam.
Mustang4lunch2 glad to hear that they made that much of an improvement. I'm going to be getting those after i do my headers. How did all those parts line up?
Old Nov 26, 2003 | 10:20 AM
94GrayV6's Avatar
Not to hijack your thread or anything, but I'm selling all my parts that I got to do the 1.7s... if anyone is thinking about getting them this is a great deal.
http://web.camaross.com/forums/showt...hreadid=197027
Old Nov 26, 2003 | 10:28 AM
yes everything lined up. i'm not sure what you fully mean by that but everything worked just fine.
Old Nov 26, 2003 | 10:34 AM
LWillmann's Avatar
drewstealth - his original post said he had the "lt4 hot cam kit 1.6's" which could have meant that he only had the rockers. That is why I was confused and asked for clarification.
Mustang4Lunch2, thanks for the info!
Old Nov 26, 2003 | 10:45 AM
Well some people had some issues with the guideplates not lineing up correctly. So thats basically what i meant. Sorry for not being clear.
Cam's maro
Aug 11, 2015 07:45 AM
TA25th
Oct 24, 2003 12:28 PM
ninetythreez
Oct 22, 2003 10:33 AM
PhantomTA
Oct 10, 2003 12:25 AM
Jason Short
Advanced Tech
39
Nov 6, 2002 02:16 PM
