bang bang bang :(
Old Apr 6, 2006 | 05:01 PM
96 trans am's Avatar
Angry bang bang bang :(
I bought a starter from autozone. I'm having problems with it. I put it on with no shims and i can hear it banging against the flywheel ( I believe thats what the sound is). Well I put one shim on, then two, then three, and finally four shims and the same thing is happening . Can someone help me out on this. Should I keep trying to put more shims on, or am I doing something wrong. It is really getting on my nerves now. Also if you have pics of your starter hooked up and unhooked can you post them.
Old Apr 6, 2006 | 05:54 PM
Re: bang bang bang :(
anyone have any ideas?
Old Apr 6, 2006 | 06:54 PM
Heatmaker's Avatar
Advanced Member
Old Apr 6, 2006 | 08:06 PM
camzaro28's Avatar
i had a similar problem, but this was with my old blazer. anyway they gave me a starter for a differnet model blazer, might have been the 3 cyl. not for sure though. but anyway they could have possibly mixed soemthing up and gave u a v6 starter if they Are differnet then ours.
just a suggestion to look into
(EDIT: 4 CYLINDER, LMAO)
44 views and nothing? Someone has to know something.
Old Apr 6, 2006 | 08:40 PM
thesoundandthefury's Avatar
When you can insert the tip of a straightened paperclip between the tip of a starter tooth gear and the valley between two flywheel gear teeth, that'll be when you've got it shimmed enough.
Old Apr 6, 2006 | 08:56 PM
Cmr0z28's Avatar
Camarocracy's Avatar
Get an AC Delco unit.And yeah, you bought it from autozone.
War Engine
Aug 21, 2015 05:28 AM
dolfan324
Jul 17, 2015 10:34 PM
Critter
Jul 13, 2015 05:51 PM
Grimm71
Jun 24, 2015 02:17 PM
kksi
Feb 16, 2015 06:49 PM
