Bang!
Old Feb 24, 2003 | 01:13 PM
vodoo-chile's Avatar
Bang!
I have a banging on the underside of my car. It is something hitting the bottom floorpan around driver's side(?) when going over bumps and dips. I have looked at the y pipe and it is secure and seems to have plenty of clearance. I have also checked the tranny mount and it also seems intact(?). What else could it be and what can I do to find out where and what it is? Thanks to everyone,
Kyle
Old Feb 24, 2003 | 01:29 PM
Gripenfelter's Avatar
Are you sure its not a bad shock?
Is it a rattle like a heat shield?
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Bang!
Kyle
sounds can be very decieving. It could be shock mounts or even a loose motor mount (doubt it, dont worry )
theres not much under there
a tranny and an exhuast, i'm betting its coming from somewhere else
Old Feb 24, 2003 | 02:33 PM
I replaced the shocks all around about 6 months ago withy no problem since then. I took the car to a guy on the board to do the cam swap in early January and started noticing the bumping then. It is not a rattle but a thud. I can feel the hit on the floor in my feet and it is audible from inside the car. I am pretty sure it is either the y pipe or tranny. I also thought motor mount but when I rev it at idle, the engine has minimal movement. Is there any way to test these three things? Thanks,
Kyle
Old Feb 24, 2003 | 03:48 PM
Lions3's Avatar
Maybe check your tranny mount.
Is it only under acceleration? Or is it only when your suspension compresses?
Old Feb 24, 2003 | 04:35 PM
When my suspension compresses. I can be cruising at 45 mph down my road and ...thump. Any ideas?
Kyle
Old Feb 24, 2003 | 05:24 PM
Fastbird93's Avatar
Shot bushing somewhere causing joints to impact each other maybe?
Old Feb 24, 2003 | 07:43 PM
94Sleeper's Avatar
This sounds a lot like a tranny mount. It is easy to check out. Get the car up on stands and jack easy on the back of the transmission and inspect the tranny mount to see if its broken.
War Engine
Aug 21, 2015 05:28 AM
dolfan324
Jul 17, 2015 10:34 PM
Critter
Jul 13, 2015 05:51 PM
Grimm71
Jun 24, 2015 02:17 PM
kksi
Feb 16, 2015 06:49 PM
