Ballancer/Damper question
Old Mar 24, 2011 | 02:31 PM
MeenZ28's Avatar
Whats the difference between a balancer and a damper? And whats the stock unit on a LT1 considered (a balancer or a damper)? What benefits would changing to something like this...
give me?
Old Mar 24, 2011 | 05:05 PM
bw_hunter's Avatar
Re: Ballancer/Damper question
The words balancer and damper are used interchangeably on these engines. However, damper is correct, balancer is not...
A damper like that would be an advantage in safety at the track, assuming it's SFI approved, and perhaps a lighter weight would allow quicker revving....
Old Mar 24, 2011 | 06:35 PM
A "damper" has a singular purpose - to absorb and minimize the torsional twist in the crankshaft that results from the firing sequence. The LT1 has a damper. It is neutral balanced, and serves no balancing function.
A balancer has an offset weight on it, to help balance the rotating assembly. The Chevy Gen 1 small blocks use a balancer with a weight. The "damper" function is integrated into the balancer, so the SBC uses an integral balancer/damper.
The stock LT1 rotating assembly is balanced externally, using a weight on the flex-plate or flywheel.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
