balancer removal ?
Old Apr 24, 2011 | 06:50 PM
twistedbowtie's Avatar
Question balancer removal ?
im replaceing to optispark on my 1995 camaro z28 6-speed and cant get harmonic balancer off the pully pullers i have tried the bolts out of the balancer will not fit through the puller.
how can i get it off? what kind of pullers can i use and where can i find them?
any help would be great thanks in advance
Old Apr 24, 2011 | 07:05 PM
henryz28's Avatar
Re: balancer removal ?
I usually just unbolt the 3 bolts and pull it off by hand.
Old Apr 24, 2011 | 07:09 PM
RamAir95TA's Avatar
Any puller (3-jaw or otherwise) will work. Every parts store known to man carries something that will work.
ive tried that man ever a pry bar and hammer the thing want move haha
so i bought a puller and the bolts are to big and can find one with bigger slots.
thanks
Old Apr 24, 2011 | 07:12 PM
okay ill try and find a three jaw puller.
thanks alott that is gonna do it
Old Apr 24, 2011 | 07:42 PM
http://shbox.com/1/pull_pulley.jpg
Old Apr 25, 2011 | 11:38 PM
henryz28's Avatar
thanks
I guess I am one of the lucky ones; now if I can just get my optisparks to stay together I will be good. Spray some pb blaster before you put the puller on it; it should help cut some of the rust, it should come right off with the puller shbox posted up. Don't hammer on it too much; I would avoid that method. Maybe you could clean it, sand it and put some paint on it so that rust doesn't build up.
Old Apr 26, 2011 | 09:46 PM
MikeGyver's Avatar
You're not trying to pull the hub off the crankshaft are you? Just unbolt the balancer from the crank hub.
Old Apr 27, 2011 | 12:38 PM
nah it was just the pulley. i just needed a 3 jaw puller .
Boss002
Jan 20, 2016 12:17 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
