Front and rear intake manifold gasket?
Old Apr 27, 2011 | 12:36 AM
LT1 POWR's Avatar
Since I'm running a single plane, is there any reason not to use a cor or rubber formed gasket for the front and rear of the intake manifold? I've got both formed cork and rubber. Why would you use rtv instead of a gasket?
Old Apr 27, 2011 | 01:29 AM
97WS6SCharged's Avatar
Re: Front and rear intake manifold gasket?
RTV seals better than the old cork/rubber end gaskets. Just put a nice thick bead front and back and be done with it.
Old Apr 27, 2011 | 01:40 AM
LT1 POWR's Avatar
Will RTV hold up to 20lbs of boost? What about a combination of a formed gasket and RTV at the edges, where the head/block/intake meet?
Old Apr 27, 2011 | 05:35 AM
bw_hunter's Avatar
It doesn't have to hold 20 pounds of boost in the crankcase....that's inside the intake tract. You may see elevated crankcase pressure but not that much, every seal would fail....
Old Apr 27, 2011 | 01:01 PM
LT1 POWR's Avatar
I woke up this morning and noticed that. Unless I plumb the PCV system wrong, it should see much, if any boost.
CARiD
Jan 27, 2015 06:27 AM
Jazsun
Dec 29, 2014 12:14 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
