Balance hub = broken
Old Mar 19, 2005 | 02:05 AM
Zachz28's Avatar
ok the the hub that is pressed onto the crankshaft on of the 3 ears broke off it is on there so hard any ideas.
p.s some one on this bored said it would brake ... you were wrong
Old Mar 19, 2005 | 09:18 AM
Re: Balance hub = broken
Do you want to start over? That makes no sense. 2:05 a. m.-maybe your mind was not clear.
Give details on exactly what you did.
Old Mar 19, 2005 | 11:24 AM
I think maybe he meant to say "someone on this board said it would not break ... you were wrong" ?
Old Mar 19, 2005 | 01:35 PM
Zachz28's Avatar
Yes ill start over
While attempting to remove My harmonic balancer hub one of the threre ears broke off and yes i did remove the bolt
Old Mar 19, 2005 | 01:36 PM
Zachz28's Avatar
yes thats right injuneer
Old Mar 19, 2005 | 03:47 PM
Robs97Z28's Avatar
you know you needed to use a socket in the middle of the hub. The socket is used so that the puller press on the crank, not the hub. The hub has a lip in the middle around the front of the crank. So, when you used the puller you were just pressing against the hub.
Old Mar 19, 2005 | 05:42 PM
94zgreenmachine's Avatar
I have a brand new hub that I never used. I bought a new balancer that had the hub with it and it was keyed so I have no use for it. It is for 95 and older cars.$10 plus shipping and you can have it. If you are interested just PM me and I'll give you my phone number.
Old Mar 19, 2005 | 10:57 PM
CeeBee94Z's Avatar
Yea I would be willing to bet thats what you did too. It took me a while to get that thing off when I did my cam swap. The best thing to do is use a 1/4" drive extension and push off that with the puller.
Old Mar 19, 2005 | 11:05 PM
Fux0redImages's Avatar
http://web.camaross.com/forums/showthread.php?t=292156
Old Mar 20, 2005 | 02:24 AM
Zachz28's Avatar
OK I got it off and i am ever so proud of myself (and my friend) we sawzalled the hub off before the snout of the crank so the timming cover would clear. Then we removed the timming cover and used a 3 jaw puller to pull the crank sprocket and what remained of the hub off.
Jeff1904
Jun 5, 2016 05:00 PM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
Daluchman1974
Sep 11, 2015 06:12 AM
maverickmk
Sep 1, 2015 09:17 PM
