BAD! water pump
Old Nov 6, 2003 | 09:41 PM
kickinthehouse's Avatar
BAD! water pump
ok guys im in the middle of fixin/replaceing a water pump
ive removed all the hoses that where in my way and all the screws it still wont budge
???? how can i get it off
also if any one has one of those mechanic books if you could scan up or type up the instructions thatd be great
damn water pump
Old Nov 6, 2003 | 09:47 PM
95grandsport's Avatar
make sure you gat all six bolts, the one that is a stud for the AIR pump is often overlooked. If you have all six bolts out, just give it a pry, heat can really seize it on there.
Old Nov 6, 2003 | 09:53 PM
thers this big metal cover thats holding the brake pump thats keeping me frrom accesing that last screw too get outt he water pump
Old Nov 6, 2003 | 10:02 PM
PaulN64's Avatar
you have to take out the air pump out also. there's one more bolt behind there to take the water pump out. I've done this before and just remember how to put it back together.
Old Nov 6, 2003 | 10:13 PM
how do i take the air pump off ?
Old Nov 6, 2003 | 10:21 PM
remove the applicable bolts. Seriously, there is 2 bolts?and a nut that is attached to a stud which runs through the water pump. I'm sorry I just told you how to take the bracket off. First you have to remove the 10mm screws that attach the rubber mounts to the bracket.(3 of them) remove A.I.R. pump then bracket. make sure you got the fan out of the way the three bolts on the pass. side and pull.
Old Nov 7, 2003 | 07:38 AM
IslandZ's Avatar
Eh you have a V6, we are prolly advising you how to take off a V8 (LT1) waterpump. Try the V6 forum.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
Zone
Jul 29, 2002 07:43 PM
