Is it bad to run at 100% duty cycle?
Old May 4, 2003 | 09:16 PM
Rodrigues's Avatar
I am just curious if running at a 100% duty cycle would cause a large horsepower loss over bigger injectors.
Old May 4, 2003 | 09:19 PM
turbo_Z's Avatar
yes! if the injectors are maxed out then its a good bet the car is running lean since they cant open more than 100%. go with some 30# SVOs they are cheap and easy to come by.
Old May 4, 2003 | 09:20 PM
Rodrigues's Avatar
They never go beyond 100%, they reach 100% right where I want to shift at 6200 rpm.
Old May 4, 2003 | 10:05 PM
Timberwolf's Avatar
would be hard to go beyond 100% wouldn't it?
Old May 5, 2003 | 07:21 AM
IDOXLR8's Avatar
Actually it is possible to be above 100% duty cycle. MY 55lb injectors were running at 120% duty cycle. Ideally you want your injector duty cycle to be around 85%. What kind of fuel system are you running??
Old May 5, 2003 | 09:17 AM
Rodrigues's Avatar
I am running the stock 24 lb injectors
Old May 5, 2003 | 10:28 AM
IDOXLR8's Avatar
You may want to try and get some 30 lbers in your car. Also whar kind of fuel pump are you running?? Are you running an Adjustable Fuel pressure regulator??
Old May 5, 2003 | 11:40 AM
Rodrigues's Avatar
Stock FPR, Stock FP, Im thinking about the 30lbers as well.
Old May 5, 2003 | 02:52 PM
rskrause's Avatar
Moderator
No matter what pulse width the PCM commands, the injectors can't be open more than 100% of the time. In fact, if the pw's approach 100% most injectors become erratic, neither fully opening nor fully closing. This is not good! It's best to stick with 80-85% max. If you need more pw to get enough fuel, get larger injectors.
Rich Krause
Old May 5, 2003 | 02:58 PM
It's possible for the PCM to calculate pulsewidths in excess of 100% DC, but it isn't possible for the injectors to run at/deliver anything over 100%... by definition, 100% is the injector open CONSTANTLY.
If you are using TTS DataMaster to get your duty cycle values, you might want to check with TTS to see if there is a bug in the program. Some of the data I see for relatively stock engines are getting duty cycles approaching 100%, and that makes no sense at all. I've suggested to several people with these oddball results that they check with TTS, but no one has done it as far as I know.
An interesting writeup on what happens to an injector as the duty cycle approaches 100%:
The last test that we run is the Tell All Test. We run each unit up in duty cycle, at 12,000 RPM, until it fails electronically. (Seen on the oscilloscope) This is prominently displayed with the laser and strobe. Most pintle type injectors fail at 86%/88% and the Disc will usually go to 92% +, depending on system pressure. All must cycle smoothly up to 85% to Pass. Bad injectors will sometimes go "static" at 70% or so and are discarded. NOTE: Most pintle injectors will increase flow rates up to 88%, 92% with Disc injectors, and then go "semi-static", half open-half closed, just before going full static. This time-out event occurs at different time/pulse width durations, in different injectors, but always produces a 50% or so Duty Cycle flow rate. This extremely dangerous situation will usually occur at the worst of times, full throttle-max boost-high RPM- just when you need 100% fuel delivery you get 50% and go dead lean. BANG!!! This problem seems to amplify a bit at higher pressures.
Old May 5, 2003 | 03:15 PM
Rodrigues's Avatar
http://kak.com/camaro/car.uni
I believe the calculations for duty cycle TTS was making were correct. The injectors were approx open 20ms near 5900 rpm and thats about the same amount of time the engine has to make two full revolutions, am I correct?
Old May 5, 2003 | 05:36 PM
rskrause's Avatar
Moderator
Yes, but it just calculates one number from another. So the fact that they correlate does not mean they are correct. What size injectors and what is your combo?
I have seen injectors go "static" and cause an engine to go boom. Not pretty.
Rich Krause
Old May 6, 2003 | 07:27 AM
Rodrigues's Avatar
I am beginning to think that the pcm4less tune is trying to give the engine a lot more fuel than it actually needs. I am running ported that flow around 265 cfm at my max lift as well as an XE 224/230 112 lsa grind.
Rich Krause
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
moneyshotz
Jul 27, 2002 06:16 AM
