bad optispark please help
Old Jan 23, 2012 | 01:51 PM
  #16
Michael T's Avatar
Re: bad optispark please help
Id check the coil wire that runs from the coil to the opti.... its like a spark plug wire, and on mine it was super corroded... pull a wire off one of the plugs swap it with the one from the opti to the coil and see if it starts..
Old Jan 23, 2012 | 03:19 PM
  #17
jrips69's Avatar
Oh ok... So that means I have to take off everything again than huh..... There suppose to be no oil at all right on the timing belt
Old Jan 24, 2012 | 03:52 PM
  #18
There is no timing "belt"..... it's a chain and there is supposed to be oil on it. I think he was suggesting (although very hard to decipher) that you should check all the seals on the timing cover to make sure that's not the source of the leak into the Opti.
I'm not sure I would agree either that most all LT1's have an intake leak at the front of the engine. Usually, it's in the back, and many of us have never had an intake manfold oil leak.
kmk7110
Jun 20, 2015 05:53 PM
jwade88
Jun 14, 2015 09:38 PM
ad356
Apr 11, 2015 11:12 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Injuneer
Dec 15, 2014 09:36 AM
