bad missfire on my 97
Old Apr 9, 2008 | 04:54 PM
just tay's Avatar
they replaced the
spark plugs and wires
water pump
distributor
two fuel injectors
its still missfiring. they've been trying to find why for a 1 & 1/2 weeks.
help???
Old Apr 9, 2008 | 05:00 PM
11secgen's Avatar
was the fuel pressure ok?
Old Apr 9, 2008 | 06:07 PM
Under what conditions does it misfire:
-cold start?
-cold idle?
-warm idle?
-low rpm/part load?
-high rpm/high load?
-runs fine until about 3 minutes after cold start?
coil?
IC Module?
leaking EGR?
Does the engine have any mod's or is it stock?
Have they scanned it? The GM enhanced parameters scan data will tell them if its a random misfire, or specific to one or more cylinders.
Who is "they", that are playing parts-replacement roulette with your car and your check book?
Old Apr 21, 2008 | 12:41 AM
97LT1Boy's Avatar
-cold start?
-cold idle?
-warm idle?
-low rpm/part load?
coil?
IC Module?
leaking EGR?
I don't mean to thread jack... but I am having a bad misfire problem myself. it does not appear until driving the car for a few minutes, and it gets progressively worse as you drive it. I thought it was just moisture in the gas since I haven't driven the car in a while, but a bottle of heat didn't change anything. the car ran fine a couple of months ago before I stopped daily driving it. now it starts up fine, but misfires bad under even slight load (the ses light even flashes) and at idle you can tell there is a miss. any ideas, I can't afford to play parts roulette.
btw, it has new plugs, wires, coil, opti, pcm, no cats to get plugged, no egr, no AIR, and new o2s.
thanks,
nick
Old Apr 23, 2008 | 02:20 AM
97LT1Boy's Avatar
does anyone have any additional input on what may cause such a bad miss to develop, especially in a car that hasn't been driven much over the last couple months.
thanks, nick
Old Apr 23, 2008 | 12:22 PM
Then why did you? As you can see, the original poster isn't getting any responses and it may be that you've contributed to that problem.
Old Apr 23, 2008 | 12:25 PM
97LT1Boy's Avatar
uhh... im having a similar problem as he is, so there really isn't sense in starting a new thread. How have I contributed to a problem? I appreciate your intellect in helping to solve the problem at hand though; good job posting pointless conversation in the thread. I'll start my own thread then, though I now doubt that I'll receive any viable information from doing that anyways.
Thanks for all your help,
Nick
Old May 6, 2008 | 11:54 PM
roycontreras8's Avatar
My 95 Z LT1 started to missing right out of the blue took to to town and ate watched the car thought window, started to leave it sounded different like low idle. Put it in gear it started getting worse by the time i hit the stop lights it was trying to die out and running ruff smelled like gas black smoke. Changed plugs wires ran the same dieing out smoke .Pluged in ob2 at auto zone it said could nt connect to computer told guy at auto zone he said i must have ob1 in my cay, but it has the ob2 plug under dash .What to do i heard that you could buy a ob1 and use two junper wires to the ob2 plug and that would work.If anyone been thought this please send me e mail Thamk You Roy at roycontreras8@aol.com
Old May 7, 2008 | 12:09 AM
Nick
Last time I checked, the Admins asked me to Moderate these forums. If you have a problem with the way I do it, contact the Admins.... I'm sure they'll be glad to hear from you. You highjacked the thread... plain and simple, and its wrong by anyone's standards. You may consider it "pointless conversation".... but I consider it my job.
Have a nice day.
Old May 7, 2008 | 12:12 AM
You already have a post going on this one, and Shoebox has given you the answer to your question regarding the jumper wires required to connect an OBD-I scanner to a 1995 16-pin OBD-II style ALDL connector. Someone also gave you the link to Shoebox's site, with a diagram of the jumper wires.
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 24, 2015 04:51 PM
vwb11356
Jul 22, 2015 06:51 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
