bad missfire on my 97
Under what conditions does it misfire:
-cold start?
-cold idle?
-warm idle?
-low rpm/part load?
-high rpm/high load?
-runs fine until about 3 minutes after cold start?
coil?
IC Module?
leaking EGR?
Does the engine have any mod's or is it stock?
Have they scanned it? The GM enhanced parameters scan data will tell them if its a random misfire, or specific to one or more cylinders.
Who is "they", that are playing parts-replacement roulette with your car and your check book?
-cold start?
-cold idle?
-warm idle?
-low rpm/part load?
coil?
IC Module?
leaking EGR?
-cold start?
-cold idle?
-warm idle?
-low rpm/part load?
coil?
IC Module?
leaking EGR?
-cold start?
-cold idle?
-warm idle?
-low rpm/part load?
coil?
IC Module?
leaking EGR?
btw, it has new plugs, wires, coil, opti, pcm, no cats to get plugged, no egr, no AIR, and new o2s.
thanks,
nick
Thanks for all your help,
Nick
My 95 Z LT1 started to missing right out of the blue took to to town and ate watched the car thought window, started to leave it sounded different like low idle. Put it in gear it started getting worse by the time i hit the stop lights it was trying to die out and running ruff smelled like gas black smoke. Changed plugs wires ran the same dieing out smoke .Pluged in ob2 at auto zone it said could nt connect to computer told guy at auto zone he said i must have ob1 in my cay, but it has the ob2 plug under dash .What to do i heard that you could buy a ob1 and use two junper wires to the ob2 plug and that would work.If anyone been thought this please send me e mail Thamk You Roy at roycontreras8@aol.com
uhh... im having a similar problem as he is, so there really isn't sense in starting a new thread. How have I contributed to a problem? I appreciate your intellect in helping to solve the problem at hand though; good job posting pointless conversation in the thread. I'll start my own thread then, though I now doubt that I'll receive any viable information from doing that anyways.
Nick
Nick
Have a nice day.
zajones
Jul 30, 2015 02:18 PM
