BAd gas smell after FULL tank?
Old Mar 14, 2006 | 07:17 PM
crAzy95z28's Avatar
any ideas as to why this happens?
I have cut open a hole on teh body to get to the fuel tank for easy access.
could this be my problem?
also usually if i have the windows up it doesnt smell but when let down, its bad.
Ive tried to trace all my fuel lines and make sure nothing is leaking and it isnt.
No leaks from anything.
im lost.
Old Mar 14, 2006 | 07:24 PM
IllusionalTA's Avatar
Re: BAd gas smell after FULL tank?
Did you pull your pump out? or just did this for ****'s and giggles? you might did you knick a line possibly?
Old Mar 14, 2006 | 07:35 PM
crAzy95z28's Avatar
it was to replace the pump. Ive checked them all and nothing.
Old Mar 14, 2006 | 07:38 PM
you might have not sealed the tank correctly.. the lil rubber o ring.. make sure you didn't rip that..
Old Mar 14, 2006 | 07:41 PM
crAzy95z28's Avatar
hmm....
ill check it out when i get my car back from shop.
thanks for you help. Still waiting on more replies
Old Mar 14, 2006 | 09:36 PM
OBE1 95Z28's Avatar
Your charcoal canister is located in the driver's side rear wheel well; it could be failing causing the gas smell.
Old Mar 14, 2006 | 11:48 PM
crAzy95z28's Avatar
those thigns fial?
if so just replace whole thing?
Old Mar 15, 2006 | 03:16 AM
Buttercup's Avatar
It's probably the charcoal canister.
One of the biggest problems is people who do not fill the tank properly. Many people will continue to fill the gas tank after the pump automatically shuts off (usually to get to the nearest dollar or something). This overfills the tank and can send liquid gasoline into the charcoal canister, flooding it.
The vapors from the CC is sent into the intake manifold through the EVAP system. You may want to check to make sure that this system is indeed working.
Old Mar 15, 2006 | 09:32 AM
Check the hoses for the canister first - both ends, at the tank and at the canister. If they are loose or cracked it will smell.
Old Mar 15, 2006 | 05:01 PM
My Iroc Z28's Avatar
I had the same issue, The hose came off the canister and you could smell raw gas all the time. Put the hose back on and smell is gone.
Old Mar 18, 2006 | 04:27 PM
plattted's Avatar
The hole you cut to access the tank and pump- get a piece of metal and some gasket material to cover the hole. I had a similar fuel smell problem-it was the "O" ring gasket it had a small tear in it and only smelled fuel when the tank was full or near full. Hopes this helps 93ZTed.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
99blackz99
Aug 6, 2002 12:48 PM
