yet another question
Old Aug 4, 2002 | 10:07 PM
99blackz99's Avatar
Post yet another question
Is it better to go to the track with a full tank or not? Ive heard arguments from both sides, saying more weight in the back is good, or less overall weight.
Old Aug 5, 2002 | 11:06 PM
jd13's Avatar
Post
I think it depends on the driver. If you can't launch too well go with a full tank. An empty tank means less weight which is good.
I've hit a few 2.0 60s on my street tires with 1/4 a tank or less.
Just gotta practice your launches.
1990 IROC-Z 5.7l
1/8: 9.06 at 76.39 mph with a 2.02 '60
- dual exhaust, underdrive pulley, 160 stat
Old Aug 6, 2002 | 12:48 PM
TedH's Avatar
Post
If you are trying to run the quickest number and fastest speed, go with 1/4-1/2 tank and work on your driving techniques.
If you are bracket racing, it is better to go with the same amount of weight each time to help maintain a constant.
I run with a full tank because I can only dial 12.00 in Street ET. I normally run 12.0's-12.1's with a full tank in hot weather. Going with 1/4 tank in the fall is putting me solidly into the 11's.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
