Bad Fuel Pump?
Old Apr 9, 2011 | 12:31 PM
Casey96SS's Avatar
Bad Fuel Pump?
My car was running fine and then I went to start it once. It ran real rough then died whenever I put my foot on the gas. I barley got it to start a couple more times then it would not start any more. It just cranks and does not fire. Had it towed home.
So I did the following tests.
1. Turned the key on. Cannot hear the fuel pump prime.
2. Depressed schaeder valve. No pressure or fuel coming out.
3. Jumped the fuel pump prime connector to the battery. Could not hear the fuel pump run.
4. Removed the cover for the fuel pump relay. I can feel the relay click when I turn the key.
5. Security light goes from blinking to solid for about 4 or 5 seconds when I turn the key and then goes out. I think the VATS is okay.
I am pretty sure the fuel pump is bad. I just wanted to check to see if there is any other tests I should perform before tearing into it. Thanks!
Old Apr 9, 2011 | 01:00 PM
bw_hunter's Avatar
Re: Bad Fuel Pump?
No, sounds like you have it right. About the only other thing to look at is the fuel pump relay. It is located under the 'dead' pedal on the drivers floor....
Good luck!
Old Apr 9, 2011 | 01:31 PM
Casey96SS's Avatar
Re: Bad Fuel Pump?
I did remove the dead pedal. I could feel the relay click when I turned the key. Is there a better way to check the relay?
Old Apr 9, 2011 | 08:43 PM
my1994z28's Avatar
Re: Bad Fuel Pump?
Sounds like you have done all you can do,Its time to replace the fuel pump..
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
