BAD engine shaking!!
Old Dec 16, 2010 | 03:08 AM
  #16
IrAnarchy's Avatar
Re: BAD engine shaking!!
@97WS6pilot, I've had the 4l60e replaced twice with the stock flexplate, and had problems with the compressor clutch. I fixed the compressor an while ago when it let go, but it had made horrible grinding noise and the shake was not as bad.
The harmonic damper was the first thing I looked at. It's a 5" diameter underdrive unit and I can't find another in any catalog. It's brushed aluminum in color, mounts to the stock 3 bolt yolk, and may be part of a kit, as the alternator pulley looks small too. The bolts on it were too big to go through the Advance universal puller.
I'll just ask santa for a scan tool. I need one too often not to have it in the toolbox.
Old Dec 18, 2010 | 02:26 AM
  #17
chevy_dude97's Avatar
Originally Posted by IrAnarchy
@I'll just ask santa for a scan tool. I need one too often not to have it in the toolbox.
yeah I leave mine in the center consol.... come in handy.
Old Dec 18, 2010 | 02:40 AM
  #18
its almost always one of three things;
Compression
does it have good compression in all cylinders?
Ignition
all wires firing(signal),
plugs firing(spark),
Fuel
injectors firing,
Good fuel pressure,
But if its not it could get really expensive,
Im not sure exactly what size the balancer should be but id check it for cracks or missing rubber,
Id try this first--->>>as far as the accys go you can take the belt off and see if it still makes the same vibration.(that would narrow it down alot if it goes away)
besides that you could even have some carbon buildup on a piston causing pre-ignition(does it knock?)
I know most of this you probably already checked but I am just tryin to brain storm lol
Old Dec 18, 2010 | 07:55 AM
  #19
Is the damper an actual integrated damper/pulley, or did someone pull the damper off and incorrectly replace it with a simple underdrive pulley, that was meant to be sandwiched between the stock damper and the hub?
Old Dec 31, 2010 | 07:08 PM
  #20
lymlyt96's Avatar
yeah thats the same thing that happened to mine the guy who put my motor together put the underdrive pulley on there and didnt put the harmonic balancer on top of it and that motor shook like a stripper tryin to make the rent... i put the balancer back on and everything went back to normal my throttle response wasnt as good but at least the motor wasnt shakin anymore.
Old Dec 31, 2010 | 11:05 PM
  #21
It shouldn't shake all that much without the damper, because its not a "balancer". But its definitely not good for the crankshaft to run without the torsional dampening effect of the damper. It could be contributing to the problem.
Old Jan 19, 2011 | 06:56 PM
  #22
any updates?
Old Jan 19, 2011 | 10:09 PM
  #23
Originally Posted by chevy_dude97
any updates?
IrAnarchy has not been back to this site since 12-20-2010 01:40 PM.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
wytblur
Aug 5, 2002 02:03 PM
dmaastr
9
Jul 1, 2002 02:22 PM
