bad blowby?
Old Mar 3, 2014 | 11:42 AM
lippy08's Avatar
Exclamation bad blowby?
so i have a 93 lt1 z28 and i notice there oil in throttle body and coming out the gromet seal on pass valve cover....is there a good way to fix this? could i eliminate this set up? could i use a breather insted of the hose?... would really like some help plz and thank you
Old Mar 3, 2014 | 12:59 PM
Re: bad blowby?
The real fix is to eliminate the blowby (probably engine overhaul). A leakdown test should tell you where you stand. A catch can is used by some that don't have excessive engine wear.
Old Mar 3, 2014 | 05:08 PM
lippy08's Avatar
Re: bad blowby?
it had 120,000 on it when i bought it and ive maybe put 15 miles on it since i bought it right before winter so id say rebuild engine too
Old Mar 3, 2014 | 05:09 PM
lippy08's Avatar
Re: bad blowby?
forgot to say thanks for answring me sry
Old Mar 3, 2014 | 06:50 PM
Re: bad blowby?
I'd recommend a leakdown test, as Rob/Shoebox suggested, before jumping to the conclusion it needs to be rebuilt. They can run 200,000 miles without a rebuild, with proper maintenance.
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
