back to changing plugs *AGAIN*
Old Jun 12, 2007 | 06:20 AM
wyldcdn's Avatar
posted it once before . Still no fixes after 500 miles
94 lt1 mods in sig
Every 500 (avg) I have slighlty fouled plugs that get worse from there
Car when its running may see 100-miles a week. Alittle track, alittle cruise.
I've tried autolites, NGK's tr6's gapped at .05 and tried .045. Same technique on tr55's. All new MSD wires, MSD coil. New opitcrap, new coolant temp in W.Pump. Cleaned MAF, cleaned Throttle body. Fuel is good. I'm going nuts. I have parts I sooooo bad want to install, but won't til this is fixed permenatly.
Old Jun 12, 2007 | 09:27 AM
BUBBA's Avatar
Has it been tuned or just programmed with a box---fouling plugs may be a result of unburned fuel, i.e, too rich. You could try a MSD ignition to ensure good spark, but I'm sensing you are just too rich. I'm certain someone else will be able to help you.
Old Jun 12, 2007 | 11:13 AM
2000GTP's Avatar
I would probably get the car scanned and see what it is doing. You shouldn't be going through plugs every 500 miles.
Old Jun 12, 2007 | 11:26 AM
Heatmaker's Avatar
Advanced Member
what do the plugs look like?
Old Jun 12, 2007 | 03:49 PM
wyldcdn's Avatar
was scanned, no codes. plugs are heavy black soot around lower ring that connects to electrode. tip is still clean. I believe a hypertech was used. Previous owner did it. I will be putting a scan to check A/F after I swap plugs. Darn I hate this...LOL
Old Jun 12, 2007 | 09:35 PM
TobyZ28's Avatar
94 lt1 mods in sig
First thing i think of with fouled plugs is rich. Second thing i think of is O2 sensors
Getting a scanner on it when its warmed up and running. You'll probably see a Lazy o2 or something.
Also check for loose manifold bolts. An exhaust leak can throw off your o2 readings too.
Old Jun 12, 2007 | 11:17 PM
wyldcdn's Avatar
Burnaby ...sweet, Home province for me (Prince Rupert)
Swapped in new O'2's last time around. Wiring harness was close to header, and melted plastic sheath. I do have bolts that come loose so tommorrow I'll be swapping plugs again, checking the header bolts. This weekend I'll be running a scan on mixture.
Old Jun 12, 2007 | 11:20 PM
2000GTP's Avatar
Was the wiring inside the harness damaged at all?
Old Jun 12, 2007 | 11:21 PM
wyldcdn's Avatar
on the O@ side yes, factory harness no. Passenger side if that helps
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
Jan 23, 2015 01:13 PM
Amshnock
14
Jan 18, 2015 11:47 AM
MJ_Z28
Aug 8, 2002 09:07 PM
