Autotap P0137 code
Old Dec 19, 2005 | 06:38 PM
Drew '97 Z28's Avatar
Autotap P0137 code
I'm new to using autotap and have a question. Is it normal for this code (P0137) to not set the SES light?
I've been having trouble with emissions testing due to readiness monitors not being ready. The SES light is not on nor has it been on at all this year. I decided to run Autotap and P0137 came up, however it also says no DTC's were found after scanning. Does anyone know if this code set off the SES or not? Thank you in advance.
Drew
Old Dec 19, 2005 | 09:10 PM
moparman's Avatar
Re: Autotap P0137 code
That code would indicate a problem with the after cat O2 sensor on the driver's side. It will set a code. Did you look at the O2 sensors to see what they were reading?
Old Dec 19, 2005 | 10:45 PM
I'm not experienced with the functionality of Autotap so to answer your question, no. I thought it was odd that I have no SES light lit and was wondering if Autotap might have found the code another time before today and saved it. As for finding out what that sensor is reading, how do I do it and what should I look for?
Old Dec 20, 2005 | 07:07 AM
moparman's Avatar
I'm not familiar with Autotap, but I presume you have to put it in some kind of diagnostic mode. Someone else will have to help you with the proper way to set up and use Autotap.
Old Dec 20, 2005 | 07:12 AM
P0137 sets when the driver's side after-cat O2 sensor has a constant voltage output below 40mV. Your scanner should be able to read virtually any sensor on the vehicle. Look at the B1S2 sensor and see if its stuck below 40mV, or moving similar to the pre-cat sensor (although with a bit less range in the swings).
If you can't figure out how to use AutoTap, try switching the after-cat O2 sensors side-to-side. If the problem (code) follows the sensor, its a faulty sensor. If the problem stays on the drivers side, its a wiring problem, cat problem, etc.
Old Dec 20, 2005 | 04:36 PM
Thanks for the replies. In the interest of pasing the emissions teat quickly I think I'm going to get O2 sims for the time being. If that works I may change my exhaust anyway. Great info Injuneer, thanks.
Ricardo
Nov 29, 2014 10:58 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
camaro98z28
Jul 9, 2002 11:02 AM
tbyrne
Jul 2, 2002 05:37 PM
