Autometer Guage Issues
Old Jun 11, 2007 | 06:07 PM
Huntr1117's Avatar
Question Autometer Guage Issues
I just installed a tranny temp guage and an A/F guage in my car yesterday and neither one work. I Checked all my grounds and power wires with a test light and they they all seem to be fine. I wired the A/F guage to the purple C20 wire comming from my PCM. The guages aren't showing any readings and they don't light up at all. Could it be because I spliced all the wires together like the ground wires and the power wires? Any suggestions?
Old Jun 11, 2007 | 07:16 PM
Heatmaker's Avatar
Advanced Member
how do you have the power wire hooked up. What did you tap into?
Old Jun 11, 2007 | 07:31 PM
Huntr1117's Avatar
I tapped into an orange power wire under my dash, my e-cutout and my radar are also tapped into this wire. It only has power when the ignition is on.
Old Jun 11, 2007 | 07:57 PM
Heatmaker's Avatar
Advanced Member
what voltage do you get to the power wire at key on?
Old Jun 11, 2007 | 09:20 PM
seawolf06's Avatar
Maybe you should check the fuse. That's a lot of things to run off that one wire.
Old Jun 11, 2007 | 09:50 PM
Huntr1117's Avatar
All the fuses are fine, my radar and my e-cutout still work fine.
Old Jun 11, 2007 | 09:53 PM
mdacton's Avatar
then you must not have 12v to it.....if not that then check your grounds
GigaMp3z
Feb 20, 2003 02:57 PM
speedy0009
Aug 21, 2002 12:48 PM
30thANNIVZ-28
Dec 23, 2001 03:23 PM
30thANNIVZ-28
Nov 28, 2001 06:35 AM
