bosch plugs ?
Old Jun 10, 2007 | 09:04 PM
chevyinside's Avatar
bosch plugs ?
tryed a surch but the only this i found was not to use them . i've been having a miss issue so i pulled one of the plugs and behold it looked like the carbon track was running right down the porcolin to the base . i think thats the issue so i'm gonna replace with acdelcos . Has any one else run it this issue ? it's a stock internal lt1 motor .
Old Jun 10, 2007 | 09:09 PM
2QUIK6's Avatar
Bosch plugs are notorious for fouling easy if the tune is just slightly off. AC Delco platniums have worked well. My favorite are NGK Irridiums, a little expensive but I have been very impressed withy their durability under a wide range of tuning issues I've had in the past.
Old Jun 10, 2007 | 09:21 PM
n2ceptor's Avatar
FYI: AC Delco plugs sometimes loose the platium puck.... Dont know if the problem has been retified....
Old Jun 10, 2007 | 09:45 PM
i'm not sure if acdelco fixed that or not . it's just weird that i put a new set of plugs in and less than 20,000 a couple of them are causing me to have a weird missfire . it isnt detecte by the computer either . it's a 1996 . i think it's creating a spark just not in the right place in the cylinder .
Old Jun 11, 2007 | 11:07 AM
2000GTP's Avatar
Have you thought about the NGKs as well?
Old Jun 11, 2007 | 11:15 AM
maybe i'll try ngk they just seem to be cheap plugs .
Old Jun 11, 2007 | 11:42 AM
Z28LT1_Just_Nasty's Avatar
I used bosch in my last two tune ups. Ran 13.3 with them haven't given me any issues. I'm switching to NGK's next time around anyway though.
Old Jun 11, 2007 | 11:56 AM
2QUIK6's Avatar
Those TR55-IX Iridiums sure ain't cheap at 7$ per plug
http://www.thunderracing.com/catalog...vid=4&pcid=102
Old Jun 11, 2007 | 12:16 PM
2000GTP's Avatar
Yeah, its the copper conductor ones that run around two bucks a piece. However, they will require quicker interval changes as compared to the iridium set.
Old Jun 11, 2007 | 01:26 PM
BUBBA's Avatar
On the other hand in re copper ones, depends on whether it's a DD or not. I.e, if you don't plan on putting lots of miles on it in a year, the coppers supposedly conduct better and are certainly less expensive. So even if it is a real PIA to change them, it might be worth it to change them every couple years anyway, just to make you aware of any other little things going on down there, e.g., loose bolts, etc.
Old Jun 11, 2007 | 03:20 PM
yah , it's a dd . i decided to go with the delco ones , just cause they were more avalible . i'll see how long they last . maybe i'll post some pis of how the bosch ones look to . just dont get why they arked like they did ?
Old Jun 11, 2007 | 07:09 PM
STAYBG87Z's Avatar
i have platinum 4's in my 96 m6 and no noticable problem,and im really not a fan of bosch.and just a question,wouldnt the platinum 4's last about 3 times longer than regular plugs with only one elctrode?
Old Jun 11, 2007 | 08:59 PM
n2ceptor's Avatar
I tried the Bosch +4s and none of them hit on every electrode.. Just 2 electrodes from want I saw... And as far as performance, no difference..Same with fuel mileage...
Old Jun 11, 2007 | 10:05 PM
sherri jo's Avatar
you know i think you just helped me!!!!!!!!
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
