Automatic Tranny Problems, changed fluid and now it slips!
Old Jun 10, 2003 | 01:54 PM
  #16
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
God bless advanced tech
Old Apr 4, 2022 | 05:13 AM
  #17
Johnnyfixit13's Avatar
Re: Automatic Tranny Problems, changed fluid and now it slips!
Send them this............
If I have recently replaced my alternator and re wired the one wire that engages the charge coming off the alternator to the positive side of the battery making it stay engaged (suggested by autozone tech) is there a possibility that the new alternator is bad causing a drop in voltage to the computer eventually causing sensors to fail or be mis read and ultimately causing a shifting issue..because the gauges either aren't working correctly or suddenly I have low engine oil pressure no battery voltage and I'm consistently on the verge of overheating while driving...
Old Apr 4, 2022 | 11:59 AM
  #18
Thread originator hasn't returned to this site since 2006. Hopefully he figured it out 19 years ago when he first posted this.
I'll never understand what drives people to dredge up ancient posts like this.
Old Apr 5, 2022 | 10:46 PM
  #19
mrmint69's Avatar
Are you unable to put the correct alternator on that can be hooked up correctly? Voltage issues or using the wrong alternator can cause things to work incorrectly. I dont know exactly why someone suggested you do that but I would attempt to go back to as close to factory as possible.
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
92ragtop
Dec 27, 2014 01:56 PM
FredM
Dec 18, 2014 01:40 PM
mattszm6
Dec 14, 2014 07:09 AM
