Auto XRay NO Codes =? Useless?
Old Sep 7, 2003 | 12:23 PM
2nd2none's Avatar
Question Auto XRay NO Codes =? Useless?
I recently had a friends scanner tell me my MAP sensor, and O2 sensor were bad, I replaced these items and the service engine soon light went away. At the same time though my car now has a flutter or vibration when I accelerate, but there is no light on. If I buy a Auto Xray will it tell me what is wrong or without a code do I have to find it manually? Does anyone have any ideas to what my problem is? I cant even spin my tires because of this flutter. It seems I have lost alot of power also. No smoke when I get on it, and the engine temp seems normal. Just this huge hesitation. EGR valve?
Old Sep 7, 2003 | 11:05 PM
Your OBD-I 1994 PCM does not have the capability of identifying misfires, so its not likely you will get a code for "fluttering"......
The scanner is simply going to give you visibility on what the readings are for a large number of the engine sensors, and the PCM calculated parameters. You need to "interpret" that data to determine if there is a problem, and what the problem is.
I have an online writeup on scanners that will explain some of what you can do with a scanner, and what the data means....
ScanMaster Writeup
Might help, might not.
cmsmith
Jan 5, 2015 07:04 AM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
Darth Xed
15
Jun 28, 2002 11:51 AM
