ATI Dampner and Front Seal
Old May 31, 2006 | 11:08 AM
Flip94ta's Avatar
Its been a long time since I've pulled the blower and crank pulley and seen the timing cover. I have an ati dampner and the front seal in the timing cover has been leaking pretty bad as of late. Can I just replace the seal or are there more seals behind the timing cover that need replaced also. Its been about five years since I been in there and I can't remember what it looks like.
And does the ati need a different seal? The old seal had slightly worn two lines in the black coating on the hub and I was wondering if a smaller/tighter seal was available.
I hope I dont have to pull the timing cover. I think part of the leakage was due to lack of sufficient crankcase ventilation and I have replaced the oil fill with a beather.
Old May 31, 2006 | 12:31 PM
1racerdude's Avatar
Re: ATI Dampner and Front Seal
The wear is normal.
If ya can get the seal out without tearing it up too bad ya can take it and go to a seal and bearing supply and get a Chicago Rawhide seal that will stop the leak.
Take the balancer hub with ya too so they can size it.
Jun 6, 2015 08:27 AM
Red_94Formula
Mar 7, 2015 09:21 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
