View Poll Results: Assembly lube or heavyweight oil?
Assembly lube
17
89.47%
Heavyweight oil
10.53%
Voters: 19. You may not vote on this poll
Re: Assembly lube or heavyweight oil?
Three cam jobs in LT1s ranging from 65-142K miles used whatever oil I was going to use in the engine 5w-30 or 10w-30 of whatever I choose to use that week. These were all fired fairly shortly after the install though, if it will be weeks or something then I would make the effort to get assembly lube.
If using something else I would say use assembly lube, if you concot something yourself do you know enough to make something that will wash cleanly once oil starts pumping???????
96SilverRam
Nov 20, 2016 11:19 AM
Apr 16, 2015 09:57 AM
