Which asp pulley?
Old Mar 2, 2004 | 03:07 PM
lt4 fd's Avatar
Which asp pulley?
On lmperformance.com there are 4 packages, 2 have a 34% underdrive and are really inexpensive and the other 2 have a lesser 23% underdrive pulley but are really expensive. I have heard thatthe asp is worth getting for its combination of 2 parts and weight savings but which one is it and whats the difference between the 34% and the 23% pulleys?
Old Mar 2, 2004 | 03:28 PM
WS Sick's Avatar
I have the steel 34% and it works fine with my 97s stock alternator. I can see if you have alot of electronics though it being a problem.
Old Mar 2, 2004 | 04:18 PM
JSK333's Avatar
The 23% one should be the integrated version that is mentioned in another thread here (the one I have).
Old Mar 2, 2004 | 04:31 PM
The 25% pulley (according to the ASP website) is an integrated damper AND pulley.... one piece, high dollars. The 34% pulley (according to the ASP website) is a pulley ONLY and sandwiches behind the stock damper.
My own experience indicates that the tiny power gains are more than offset by charging issues, at least with the combination of the 25% U/D damper/pulley and the 15% U/D alternator pulley.
Old Mar 2, 2004 | 06:54 PM
lt4 fd's Avatar
Well like you said though charging shouldnt be an issue with the overdriven alt pulley...
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Black Sunshine/ 00SS
Aug 26, 2002 09:26 PM
