Architecture of AC Delete?
Old Mar 20, 2005 | 12:30 AM
LT1Cruiser's Avatar
Gday guys
dropped my '95 LT1 in the hole of the offroader Im building (finally), and the ac pump is too close to the steering pump for comfort. Im looking at the ac delete pulley but am just wondering if that is gonna increase the clearnace on the right side? It looks smaller but apparently it uses the same belt, can anyone comment on whether this will slim down that part of my belt system? Thanks in advance. Matt
Old Mar 20, 2005 | 01:14 AM
Spinner's Avatar
Re: Architecture of AC Delete?
A/C delete pully is smaller then the factory a/c pully by a small amount. My car needed a shorter belt
Old Mar 20, 2005 | 02:31 AM
LT1Cruiser's Avatar
thanks spinner, can you define small amount
Old Mar 20, 2005 | 03:37 AM
sssalah's Avatar
The pulley on the ac delete is smaller than the compressor pulley but it is shiffted to the left also. I had to change my belt with one thats about 3/8" shorter for a perfect fit. I'm also using march crank pulley and mba alternater overdrive pulley and my belt is 1490 mm.
Old Mar 20, 2005 | 08:16 AM
SMOKNZ's Avatar
I took a 1LE bracket and flipped it around and then cut off the part that had the bolt hole with nothing to bolt to. I was able to pass a 3" downpipe from a turbo thru that area. I needed a little more than 3" shorter belt as well.
If you don't understand what I'm trying to tell you, how 'bout a pic:
http://www.bytehead.com/~dunk/2-14-04.html
It's the 5th pic down. Works really well with no belt rubbing issues at all.
Old Mar 20, 2005 | 08:39 AM
Are you keeping the power steering in your "offroader"? If not, you might be able to use the relocation bracket that Madman and/or SJM Manufacturing sell for moving the alternator to the bottom of the engine. That way, you shouldn't even need the front accessory bracket.
Old Mar 20, 2005 | 01:32 PM
LT1Cruiser's Avatar
Thanks smoknz, that is exactly what Im after. Im assuming youve had no issues with reduced strength of the modified bracket? Injuneer, yes Im retaining the powersteer on my 'offroader'. My 'offroader' is actually a heavily modified Toyota Landcruiser and Im using the chevy ps unit not the Toyota one. I didnt specify exactly what my 'offroader' was since everyone around here seems to hate 'ricers' and I was keen for some positive input on my project.
Cheers
Matt
Old Mar 20, 2005 | 05:57 PM
SMOKNZ's Avatar
No problems, There is still some heavy duty ribbing on the back yet. It isn't going anywhere.
tnmotown
Aug 10, 2015 11:52 PM
alex5366
Mar 8, 2015 11:32 AM
Doug Harden
24
Jan 10, 2003 09:28 AM
NVMYTA
Nov 23, 2002 06:04 PM
Mike 99 Black T/A
Oct 4, 2002 12:58 PM
