Anyone Running A ZZ4 or ZZ3 Cam?
Old Oct 3, 2003 | 10:44 AM
  #16
rocmemphis's Avatar
I received the ZZ3 cam in a screwed up LT4 Hotcam purchase and I will tell you that it will not fit a vented opti application unless you do some modifications. You would need a longer dowel pin and you would have to drill out the center to accept the opti. Now it might work fine on a 93-94 LT1 but I am not for sure.
Old Oct 3, 2003 | 10:49 AM
  #17
95 Z/28 LT1's Avatar
Super Moderator
Well, looks like I will be getting a custom grind of it then. Now I just need some specs.
Old Oct 3, 2003 | 11:22 AM
  #18
Super Moderator
Hmmm, Interesting.
I called Comp cams, Crane cams, and Isky.
Comp offers a 206/230 with .480/.510 lift 112 LSA
Crane Offers a 210/224 with .479/.518 lift 112 LSA
Isky offers a 209/217 with .465/.485 lift 112 LSA
The ZZ4 specs I am trying to match are 208/221 with .474/.510
All the lfts are with a 1.5 rocker BTW.
Any recomendations?
parkers Z28
Mar 11, 2016 08:14 PM
Amshnock
14
Jan 18, 2015 11:47 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Queens94z28
Nov 20, 2014 06:03 PM
