Anyone running Trick Flow Roller Rockers?
Old Mar 4, 2013 | 09:55 PM
BMX Dad's Avatar
Anyone running Trick Flow (TFS-31400521) Roller Rockers?
Stud Mount, Full Roller, Aluminum, 1.6 Ratio, 7/16 in. Stud, Chevy, Small Block
Old Mar 5, 2013 | 09:49 AM
Re: Anyone running Trick Flow Roller Rockers?
The Trick Flow listing for that part shows it only fits through 1987. You need a "narrow body" rocker for the LT1, with some rocker designs.
Old Mar 5, 2013 | 02:52 PM
BMX Dad's Avatar
Thank you
Old Mar 5, 2013 | 04:47 PM
Chimera96's Avatar
COMP 1305-16 NSA for 7/16 stud(if you are getting SA than look up part #)
for stock valve covers you need to trim (or bend) the x braces inside the valve cover
see bottom of page:
LT1 Engine Fact Page | Golen Engine
Crane makes a "narrow body" aluminum RR that is plug & play, no valve cover triming. Available in SA and NSA 3/8 or 7/17 dtud
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
1775.Z28
Jan 11, 2015 10:51 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
