anyone running a mini starter>
Old Jun 1, 2009 | 05:53 PM
oneqwkfbody's Avatar
if so what brand. this is for a 93 z28 auto. time to upgrade
i saw some on jegs...just wondering how they worked out...and if they are a little different to install versus a stock style starter. i am leaning toward the powermaster 9000 hitachi style starter on jegs.com
anyone with info...anyone?
thanks
b
or alternatively...where can i get an lt4 starter...or shouldi just ask for a 93 corvette starter? i read that on some other threads here...
tia
Old Jun 1, 2009 | 06:13 PM
Another Red Z's Avatar
I have one of Jegs house brand mini on my car , it works find with SLP mids. I did have to cut the end near the oil pan deeper . It would not bolt up without hitting the flange. I think I took off about .200 or so . You might be able to beat the flange flat but I work in a tool shop and went with cutting the stater instead.
Old Jun 1, 2009 | 07:06 PM
do you happen to have a part number?
thanks for info...
i just wanted to make sure the mini starters would bolt up to an lt1 without much if any hassle... i can grind if i need to....have dremel
Old Jun 1, 2009 | 07:54 PM
RamAir95TA's Avatar
I used the Jegs (formerly CVR) 555-10001 starter. It's adjustable, and cleared my LPPs nicely.
Old Jun 1, 2009 | 08:23 PM
merim123's Avatar
i also have the jegs hitachi style that;s multi indexable. i don't recall the part number, but it was more cash then the normal part #. i found the picture of it on summit , part # SUM-829100 . i did buy it based on a search on here, so may help to do some searching for hitachi part numbers and you'll get it. i also have lpps and my experience was tough. i should have installed the starter while i had the engine out of the car. I put my headers on first, then put the motor in the car, then the starter after everything was in the car. it was tough to get the bolt on the passenger side as there is no clearance on the lpp's to turn that bolt directly. you have to work with the 1/4 ratchet's and go slow... took a while, but no clearance issues.
Old Jun 1, 2009 | 09:31 PM
I believe this was the starter I used http://www.jegs.com/i/JEGS/555/10001/10002/-1 .
AW/whiteZ-28
Aug 22, 2002 11:53 PM
My94RedZ28A4
Aug 11, 2002 10:04 PM
MJ_Z28
Aug 7, 2002 07:15 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
guionM
Jul 21, 2002 04:38 PM
