Anyone Running Dart's LT1s?
Old Apr 3, 2009 | 05:51 PM
  #31
JAKEJR's Avatar
Well, guys, let's stick a fork in it 'cause it's done.
My new Dart Pro1 180cc were delivered by FedEx this morning. I plan to take them over to Dennis Wells Racing next week to have them flowed because I need those numbers to give to Bryan at PCMFORLESS who's going to reprogram my PCM.
Compared to the 212cfm the stock heads are reported to flow, I'll see a nice enough power improvement.
I've been following a GMHTP 355 build up using the same Dart heads, out of the box, and so far they've hit 459 HP on the engine dyno with a relatively mild XFI cam - something like 224/230 on 113s. That's plenty for my purposes.
Sure, I could have the heads ported, stuff in a slightly wilder cam, fool with the intake and exhaust and end up at 500, but that was never my plan. Gotta stick to the plan.
So now I can direct my efforts to camshaft selection. I'm still looking at Comp's CRC lobes which'll give me right at .600 valve lift with Scorpion 1.7s on 7/16" studs.
Now, I'm just considering what LSA to have it ground on and what intake/exhaust duration split I'll go with.
Ain't this fun!! Yea, I'm a homework addict but, hey, I really love doing all this stuff; it's better than sex.
Well, no, not really, LOL
Jake
West Point ROCKS!
Old Apr 3, 2009 | 06:43 PM
  #32
ulakovic22's Avatar
Post up your results from the flow sheet, are you going to have the intake/exhaust runners cc'd?
Old Apr 3, 2009 | 06:51 PM
  #33
JAKEJR's Avatar
Sure, I'll post the flow numbers. I hadn't thought about having the ccing done, but I might as well.
From what I've read, I can expect the intakes to measure out in the high 180s; last specific numbers I saw were 189.8cc.
One guy on dartheads.com posted his checked at 191, then there was a big broo-haha about why are they advertised as 180s and check larger than that. I believe the moderator shut down that thread.
Jake
Old Apr 3, 2009 | 07:53 PM
  #34
Orr89rocz's Avatar
That be a nice choice of cam for that motor. very idle stable and will make a ton of power up to 6200 rpm
Old Apr 3, 2009 | 07:58 PM
  #35
JAKEJR's Avatar
GMHPT mag had a torque dip that recovered. They theorized that a tighter LSA would eliminate that.
So, what are your thoughts on the LSA?
Thanks for the feed-back.
Jake
West Point ROCKS!
Old Apr 3, 2009 | 08:08 PM
  #36
JAKEJR's Avatar
I just checked and the torque drop began about about 3000/3100 and didn't recover to that point until 3800/3900.
Jake
West Point ROCKS!
Old Apr 3, 2009 | 10:49 PM
  #37
Orr89rocz's Avatar
LT1's like tight lsa. throw that cam on a 110-111 and that motor will wake up.
You could even do 218/224 xfi on a 110 and make good power
Old Apr 3, 2009 | 11:50 PM
  #38
JAKEJR's Avatar
Thanks for that.
Jake
oldschool
Feb 9, 2016 09:21 PM
ddr698
Jan 9, 2015 10:05 AM
97z28k&N
Jan 9, 2015 04:58 AM
Camaro90RS
Jul 23, 2002 07:57 AM
