Anyone running an AFR headed LT1?
Old Jan 8, 2004 | 09:23 AM
  #31
WS Sick's Avatar
I have the 190 CC street cnc job AFRs on my 383 it runs real good but I am going to have them ported to get more. The machine shop that did my block work flowed my heads for me and they hit 254 cfm @ .550 lift . Before I had the 383 I had them on a 350 with 6 inch rods, forged pistons and a cc305 cam (11:1 comp) and it trapped at 113 best and ran low 12s (all at around 1200 ft ele). I would like to bolt a set of 210s on my motor to see how much more it does, or should i just have the 190s ported good with a vj?
Old Jan 8, 2004 | 09:24 AM
  #32
Highlander's Avatar
Get the 210s with the CNC race ready.. for hte money best bang for the buck. 2045 cant go wrong
Old Jan 9, 2004 | 12:12 AM
  #33
Turbo6's Avatar
I've got a set of AFR 220's on order for my motor. Hopefully when they come in at Thunder Racing we'll see some good numbers out of them. I ordered the full Competition set.
I just realized, engineermike, that you and I have talked before at the track. I believe I was there when you made those 11.0 passes in your 3rd gen. I was telling you that I was gonna try to beat that 121 mph that night in my '87 Turbo Buick. Well, never did it. Went 11.1 @ 120 @ 21 lbs of boost. I remember back then being amazed at the times you were getting out of that car w/ the hydraulic cam and fairly mild setup. I see based on your sig that you have upgraded!
Old Jan 9, 2004 | 07:51 AM
  #34
rskrause's Avatar
Moderator
Originally posted by engineermike
We flow tested some at Thunder Racing.
The Competition heads outflowed the Race Ready's by about 5 - 10 cfm from .200 - .400 lift. They flowed the same at .500". At .600 and .700, the Competitions did about 10 - 15 more cfm.
Personally, I'd get the Race Ready's, then have a QUALITY valve job performed and blended into the bowls and chamber. A shop will typically charge $250 - $300 for this work and they should pick up 10 - 15 cfm throughout the range. The AFR valve job isn't great.
Mike
Ditto on the AFR valve job. I bought my AFR's as a street 195cc casting. Out of the box here are the intake flows before and after a valve job.
.1 68/77
.2 129/143
.3 186/197
.4 233/235
.5 253/260
.6 261/261
.7 263/267
.8 264/268
At low lift, the valve job was worth over 10cfm.
Rich Krause
Old Jan 9, 2004 | 08:21 AM
  #35
engineermike's Avatar
I remember you! That's been a while back, huh?
Those Competition 220's will really flow well. They have flowed 210 Competitions and 220 Race Ready's and they both did 290+ cfm out the box. Yours should get close to 300.
About the car upgrade, I figured that if I could run 11.0 at 122.7 mph with a 383 and 210's NA, then it would really haul if I had a 383, 210's, and 12# boost.
Mike
Old Jan 9, 2004 | 09:37 AM
  #36
Highlander's Avatar
Competition ready not worth it?
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
