anyone run no ac and asp replacement crank pulley if so what belt?
Old Dec 30, 2005 | 11:57 PM
red96z's Avatar
not the piggy back pulley the replacement and replacement pulley for ac i need belt. would the belt size be the same if you had the piggyback version? if so then both are the same.
Old Dec 31, 2005 | 03:03 AM
Spinner's Avatar
Re: anyone run no ac and asp replacement crank pulley if so what belt?
Needed 1 inch shorter then the ASP belt with an AC delete on my car, the ASP one was just too loose on there.
This is the ASP pulley I had
HectorM52
Jun 23, 2016 08:42 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
1LEThumper
Jul 14, 2003 12:45 PM
