Anyone have trouble with Aeromotive Fuel Pressure Regulators
I had a few injectors acting up so today I installed a set of SVO 24 LB injectors and A Aeromotive Adjustable fuel pressure regulator. I checked the fuel pressure and it was over 60. I tried a few things not to help. I reinstalled my old one and it read 46 LB like before. I am just checking to see if anyone else has had this happen.
Mark
Oh P.S. car runs do much better with all 8 firing
Mark
I bought an Aeromotive AFPR and it was pure junk. It is probably one of the worst fitting and functioning items that I have ever owned. The fit was horrible and when I did finally get it installed it wouldn't hold pressure correctly. I removed it and reinstalled the stock regulator. It was amazing how easy the stock regulator was to install. It only took about 5 minutes to reinstall after pulling the Aeromotive. Luckily I bought it from Summit and they took it back no questions asked and gave me a full refund.
Originally posted by HoneyCombs
md1 I had the same mother f-ing problem, I actually just installed & uninstalled it thurs night, i was very pissed off
p.s what kind of problems did your car show when the injectors where acting up?
for 219.00 for a set I am happy
Originally posted by 97WS6SCharged
Statistically speaking, at least one of them has to work, I guess.
Frank
Mine popped last year on the highway. Diaphram or whatever let go. Fuel pressure shot up on the brand new build and washed the rings out. I had to pull the motor and rering and bearing it this winter because of the piece of crap. Aeromotive FPR =
Yes, you can use larger injectors with a stock regulator. As long as you can supply fuel to the motor in the volume that it needs, the stock regulator will keep the pressure constant. I believe Rich (rskrause) made 700 hp on a stock regulator.
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
