Anyone have a rist pin slap or come out?
Old Apr 27, 2004 | 03:01 PM
  #16
dnz28's Avatar
check piston to wall clearances
Old Apr 27, 2004 | 04:14 PM
  #17
ONELOUDKAR's Avatar
dnz, what will that tell me? what should it be?
Old Apr 27, 2004 | 04:30 PM
  #18
WS Sick's Avatar
The piston to wall clearnace will tell you if the pistons are still fitting good in the bore. If you have metal flakes run a magnet through and see if it is non ferrous or Iron or steel. If its iron or steel , you'll be replacing hard parts. (like the crank).
I have seen pressed in wrist pins (like what a stock LT1 has) elongate the whole it goes through in the pison, it actually makes a double tap sound when it does this. If your wrist pin comes out nothing but evil things can happen. (like big windows in the side of the block etc.)
Old Apr 27, 2004 | 04:35 PM
  #19
ONELOUDKAR's Avatar
WS, wouldn't I have marks all over my crank if that was the case?
Old Apr 27, 2004 | 04:43 PM
  #20
WS Sick's Avatar
Yes on one rod journal (or more) you would have uneven rediculous wear and the bearing will have "turned" on the surface free of the rod.
Old Apr 27, 2004 | 04:51 PM
  #21
ONELOUDKAR's Avatar
Well we have checked the crank and it is spotless. We saw one main bearing that looked a little tapered I guess you would call it. Two spots on 1 bearing main bearing. Other than that, the crank he said looked awesome still. Could I have caught this soon enough to just get a few specks of metal in my oil? I mean there was just little to none really... nothing to the matter of it looking silver or anything. Did I catch it soon enough? Spun bearing that is? All the tabs are still fine on the bearing too though?????
Old Apr 27, 2004 | 04:53 PM
  #22
WS Sick's Avatar
Was it tapered on the butt ends that face the other bearing half? if so it could have been the beginning.
Old Apr 27, 2004 | 04:56 PM
  #23
Leedogg 96TA's Avatar
Exactly what happened to mine....that;'s why I have the 383 now...
Sounds like about 3 lifters tapping in the engine...but it sounds like it is down in the engine.
  #24
ONELOUDKAR's Avatar
Nope
Old Apr 27, 2004 | 05:00 PM
  #25
ONELOUDKAR's Avatar
Let me ask this.... would I get a knock if it was just in the begining?
Novo
Jun 14, 2016 02:58 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
