Anyone have a rist pin slap or come out?
Old Apr 27, 2004 | 07:34 AM
ONELOUDKAR's Avatar
just wondering what type of noise it gives off!
-Mike
Old Apr 27, 2004 | 09:21 AM
TheCap10's Avatar
I believe that I may be a victim too. I get a light "tap tap tap" at warm idle only. Not there under load, when cruising, or when cold.
Oil psi is 20 when idle and warm... 40-50 when cruising warm.
I had considered rod knock, however... it's been going for thousands of miles now like this, and it's not getting any worse.
J
Old Apr 27, 2004 | 09:57 AM
ONELOUDKAR's Avatar
My tap noise is pretty loud. Do you know if a rist pin is dangerous for a car to keep driving it?
Old Apr 27, 2004 | 10:45 AM
Serene's Avatar
I'm sure you would know if a wrist pin came out
Wouldnt be pretty
Old Apr 27, 2004 | 11:21 AM
ONELOUDKAR's Avatar
Well.. what would happen if did did come out? Do they come out or just slap around on stuff?
-Mike
Old Apr 27, 2004 | 11:49 AM
Serene's Avatar
basically, destroy the block.
Old Apr 27, 2004 | 11:52 AM
ONELOUDKAR's Avatar
Serene, has it happened to you?
Old Apr 27, 2004 | 12:14 PM
Serene's Avatar
no but its not hard to imagine what it would do.
Old Apr 27, 2004 | 12:24 PM
ONELOUDKAR's Avatar
Anyone else have any facts or opinions on this matter?
Old Apr 27, 2004 | 12:37 PM
badblackta's Avatar
if a wrist pin comes out the connecting rod and the piston separate, so any number of things could happen. You would probably hear a loud clunk then some grinding noise.
Old Apr 27, 2004 | 12:47 PM
ONELOUDKAR's Avatar
So do you think I could eliminate that to be my problem? All I am hearing is the tapping noise The bearings are going to be replaced here shortly and I am just crossing my fingers that when we crank the car, that fixed the problem.
Old Apr 27, 2004 | 12:55 PM
badblackta's Avatar
yeah if you can still drive the car then I would say that a wrist pin is not your problem. The bearings may fix it but are you rebuilding the whole motor or just replacing the bearings? If they crank has some wear to it, you might want to consider going through the whole thing. Prob not what you want to hear
Old Apr 27, 2004 | 01:16 PM
ONELOUDKAR's Avatar
Just doing the bearings... the crank looks new and you can still see the honed markings. There were very small flakes in my oil but I am just hoping that they came from the bearings and nothing else. Where else can the shavings come from?
-Mike
Old Apr 27, 2004 | 01:37 PM
badblackta's Avatar
Im gonna say that the metal flakes are from the bearings. Without seeing the motor there isnt a real good way to tell.
Old Apr 27, 2004 | 02:08 PM
ONELOUDKAR's Avatar
Well I just hope that is what it is. There has been so many problems come through with this car.
